RedFrame
Checked the continuity of the cable this morning and didn't really get any clear results, so decided to complete a more detailed trace of the cable from the panel to the regulator, after running down the back of the oven and fridge it exits through the floor and transits the door/step outside the van along with a bunch of other cables, while "down under" I found the cable had been joined for some reason. When I poked and pulled the cable to get a better idea of how good the connections were I found this...
I guess that might be the issue...
I've ordered a shunt thing and a bunch of MC4 connectors as the connections "up top" are the same as those you can see above, so I want to replace those too, but I will need to get hold of some cable to suit, the current cable's outer casing is 8mm and I can't see anything on flea bay that would match, could anyone advise?
Thank you for all your help so far.
Red, Chris and Bannock
