Chausson (Transit) Flash 10 tyre pressures (2 Viewers)
leeboy
136
61
Sheffield
newbie
Hi ,
try www.tyresafe.org as tyre pressures alter depending on axle weight. It is much better and safer to weigh your vehicle when loaded and alter pressures accordingly. I'm on a trip around France at the moment with scooter mounted on the rear, no problems at all and front and rear pressures well below the max 69 psi as stated on the side wall. Too high a pressure and the van will bounce all over.
regards,
Lee...
Wombles
10,808
11,132
SW England
A few years now
Should be a sticker inside one of cab doors - passenger?
Mar 21, 2010
2,486
2,993
Don't use the pressures on the door, as these are for the Transit van and NOT the MH. Best way is to get your van weighed front and back axles, then phone Continental who will give the proper pressures.
colyboy
g8ysn
638
417
ng219ep
chausson allegro 96 /3.250klg - front 5.5 bar rear 5.0 bar +/_ .o5 bar
May 29, 2013
2,593
19,195
Tyneside
Chausson best of Flash 10
Several years now
colyboy
The Chausson manual which comes with the MH advises you to inflate the tyre pressure to the figures given on the plate on the front door. I run mine a few psi lower than the figures given.
