Chausson Flash queries | MotorhomeFun | The Motorhome Support and Social Network
glyndwr
43
23
Abergavenny
coach
since 1984 Chausson atm
Couple of questions, can you fit dual leisure batteries if so how and where do you put the second one from the main under the passenger seat, all I have found is tilt the seat and unscrew the cover plate but can't really get at it, so do you have to remove the seat first?
Jan 19, 2014
4,158
12,829
south shields
Chausson 620 welcoome
since 1990
Ive got a 620.... and i suspect they are all much of a muchness...
You can get a second battery alongside the original , which as you say is under the passanger seat...
The seat does need to be removed to fit it and you may well have to alter the battery securing plate thats fitted to the single battery to accommodate the second battery...
Usual warning about the weight of the seat... may help have someone else to help lift it off and replace it...
Andy
Oct 6, 2016
934
2,376
Pembrokeshire
Chasson 510
I asked this question some time ago. Got an answer that was put the two batteries across the van. Ratbher than front to back. Ours is a ford.
Picture in ford section forum. Still not done so don’ t know if seat has to come off.
May 29, 2013
1,622
6,560
Tyneside
Chausson best of Flash 10
Several years now
I am going to do the same job this winter. Two batteries will fit inside the space under the passenger seat. The seat does have to be removed and it is a heavy beast. Other than that the job looks dead easy, (famous last words).
G
glyndwr
43
23
Abergavenny
coach
Thanks guys , ours is a Ford too had another look today and see that the main battery for starting is under the drivers seat , spoke to a mechanic yesterday and he is saying the battery can be removed without removing the seat , I slid the seat all the way forward and removed the cover disc but cant see how the leisure battery will fit through the hole even if the starting battery will do , surely even if another battery will fit even long ways you would be limited in amperage due to the space .
Dec 28, 2016
134
146
North Wales
Chausson Best of 510
Newbie
We have a 2018 transit 627GA & the dealer fitted X2 110AH batteries under the passenger seat so can be done!
As for fitting no idea, sorry!
Rhino Installs
West Country Motorhomes
Friendly professional service from qualified technicians
