margaret894
- Nov 12, 2022
- 3
- 0
- Chausson 708
The headlights and external lights keep coming on, I turn them off and ( minutes later they’re back on again. What do I do?
What year is it? Is it on a Ford base vehicle?The headlights and external lights keep coming on, I turn them off and ( minutes later they’re back on again. What do I do?
Dashboard lights, amber lights and headlights are coming on. The van is sitting outside my house. I am putting them off with the remote key. Plus I’ve tried the manual key on the habitation door. All doors are locked. I come in and they all go on again after 5 minutes. I am up and down like a yo-yo trying to find a reason. Nothing to do with requiring exorcism! I need technical advice - not supernatural advice!I'm guessing that the vehicle is new to you, or have you been using it for some time without this issue?
Do you mean that the dashboard lighting switch turns itself on?
How are you turning the lights off? Manually at the dashboard switch?
By 'external lights' do you mean the vehicle's rear lights and the amber side marker lights?
Sorry for seemingly daft questions but I can't visualise the very odd situation.
(Or maybe you need an exorcist?)
It is 2021 and a Ford baseWhat year is it? Is it on a Ford base vehicle?
Purely guessing that it could be related to stray radio interference from a nearby source affecting the alarm/immobiliser but IKBA technical about alarms/immobilisers so can't help with that possibility.Dashboard lights, amber lights and headlights are coming on. The van is sitting outside my house. I am putting them off with the remote key. Plus I’ve tried the manual key on the habitation door. All doors are locked. I come in and they all go on again after 5 minutes. I am up and down like a yo-yo trying to find a reason. Nothing to do with requiring exorcism! I need technical advice - not supernatural advice!
MargaretPurely guessing that it could be related to stray radio interference from a nearby source affecting the alarm/immobiliser but IKBA technical about alarms/immobilisers so can't help with that possibility.
Is this the first time you've parked it in that spot?
EricThis was reported on the Chausson owners group Facebook page. I will not copy across from that page as it is a private group. However some detail below.
"With further discussion with Ford the source of the short is the C311 connector which is located on the passenger side of the van in the dash under the cup holder. " "This happens from condensation from the windscreen" "This damage causes the BCM to go into safe mode. The flashing headlights indicates this."
Hope this helps
Eric
