I've thought about that but they would charge at way over C5 rate. Don't think gels like being charged and discharged aggressively.A better solution might be to insert a B2B.
Depending on the size B2B you fit, the correct size it will be better for them as Gels have a low internal resistance when flat, I've clocked 45 amps from the standard split charge setup.I've thought about that but they would charge at way over C5 rate. Don't think gels like being charged and discharged aggressively.
My CTEK B2B only charges at 20 amps, but at least it provides the correct charging profile.I've thought about that but they would charge at way over C5 rate. Don't think gels like being charged and discharged aggressively.
Some B2Bs (eg Sterling) have an option for half power, so 40A B2B can be set to 20A. Useful for example if you only have one battery, but might get a second one in the future.I've thought about that but they would charge at way over C5 rate. Don't think gels like being charged and discharged aggressively.
