mikey70
- Nov 4, 2017
- 36
- 1
just a quickie ! Anyone know please if just starting & running the van will charge the leisure battery from the alternator without driving it ? Thanks
Yes Lenny but that depends on the age of your vehicle, you have a new one. The op may have an old one. A ten year old diesel will run all day on tick-over. A fifteen year old one will run for a year on tick-over.Yes it will but it will do a good job of wrecking your CAT, DPF & engine, diesels should be driven off directly after starting.
I agree Steve it won't do as much damage but still is not good for them. The bores can still glaze and diesels very seldom achive full operating temerature on tickover which can lead to condensation of water in the oil which can be an engine wrecker.Yes Lenny but that depends on the age of your vehicle, you have a new one. The op may have an old one. A ten year old diesel will run all day on tick-over. A fifteen year old one will run for a year on tick-over.
Normally good on a Hymer, on ours we get an initial charge of 20-22 amps dropping to 8-10 amps after ½ hour, Fiat standard alternator.I don’t find engine charging of the leisure battery very effective, even on a longer run. My understanding is that modern smart alternators drop the voltage as soon as the engine battery is full, to reduce fuel consumption and emissions. I am in the process of installing a battery to battery charger which is supposed to overcome the problem.
