Changing vehicle battery
I've no idea but someone else might see it & be able to help.
Should be fine, as there will be no signal to the EBL unless the engine is running.
I can't turn our EBL 4-105 off, (no external switch) but I do make sure that the MH is disconnected from mains power, and that the fuse for the solar panels is removed, and that I have isolated the Sterling B2B unit, before disconnecting any batteries, including the starter battery. (y)
Good luck,
Jock. :)
