Changing to a shurflo pump from standard sub (1 Viewer)
Jul 26, 2015
297
199
Devon
Hymer
since 1999
Our Hymer has a standard submersible pump but would like to increase the pressure and install a shurflo pump. Can i find a good place to install the pump and just take a inlet pipe to the tank and then reconnect the outlet pipe that feeds the taps? Also just keep the taps running on the switches?
Many thanks..
43,451
50,435
With a pressure pump you need a permanent 12v supply.
The tap microswitch wires aren't up to the job for a pressurised pump.
To be safe I would fit a stub with sealing washers in the tank side and connect to that to minimise leaks
Oct 14, 2007
4,042
6,391
Rochester
Auto-Trail Mohawk
17 fun filled years
Are you confident that the system can handle the inreased pressure?
bluesurf989
Jul 26, 2015
297
199
Devon
Hymer
since 1999
No im not sure it can handle the pressure to be honest just wondered if anybody had done it on a hymer!
What do you mean John a sub with sealing washes..
The pump in the moho is new but not happy with he pressure especially in the shower.
Is there any alternatives?
43,451
50,435
Something like this.....
Of course, you need to get a hand in the tank to fit it.
https://www.jtmplumbing.co.uk/john-guest-speedfit-c432/john-guest-speedfit-fittings-c167/john-guest-speedfit-jg-speedfit-bulkhead-elbow-15mm-x-3-4-p4300/s4301?utm_source=google&utm_medium=cpc&utm_term=john-guest-speedfit-jg-speedfit-bulkhead-elbow-size-15mm-x-3-4-quot-cm551516w&utm_campaign=product+listing+ads&cid=GBP&glCurrency=GBP&glCountry=GB&gclid=CjwKCAiA8OmdBhAgEiwAShr402qLrl6q4HxLWJ_SeA0zz8ISThpts9CQBVYQlMGCcfFEfPB6k2l1RxoCTBkQAvD_BwE
Oct 14, 2007
4,042
6,391
Rochester
Auto-Trail Mohawk
17 fun filled years
bluesurf989 The thread below may help.
