Changing hab wc light bulb
autoswan
Swansea
coach built
i`m a newbie
How do you remove light cover to check bulbs popped before I twist it which it doesn't seem to want to turn or i take a knife to it please ?
On my Hymer
Turn anti-clockwise
First the bezel
Second the cover twist again :D
The out with bulb .
Just had to check a moment ago
It wouldn't turn but I got it to pop off , bulbs ok so need to find which fuse goes to it as all other hab lights work except the 2 in toilet and shower which is a mini fluorescent?
Only fuses are on the sergeant power pack unit I assume, so with prise them out and check them next.
Bulb was ok fuses ok so hoping light fitting is ok need to get meter that reads 12v to check current to switch and fitting?
Its not on a 2 way circuit with the other switch by the hab door step is it?
Took me a while to figure it out fist time I encountered it on our MH!!
Barry
I'm not great with electrickery the light switch is in the wc room I will check if any other fuses next to hab battery are there any elsewhere ?
Then take wires out of light switch and check if power getting to them using meter, and go from there ?
