D
Deleted member 29692
He was an Inspector with the traffic division, so I assume it to be correct.
Knowing quite a few serving policemen I'd assume the opposite
It is the percentage of the width of the tyre, not a 'mm' measurement ...On 15" wheels Camping tyres are 70 profile on 16" wheels they are 75, work that one out.
I am not sure that is right, and if it is several of the cars we have owned over the years were and are illegal, as is my existing motorhome. I always check my speedos against the satnav figures, which are generally accurate to within 1% if you are travelling at a steady speed on a straight level section of road. My motorhome speedo reads about 5% high, my present car is about 3% high and the wife's car is pretty well spot on.The speedo is not meant to be accurate. By law it has to 'overread' by a minimum 7% . This prevents the defence, when caught speeding, that the speedo is 'incorrect' & blamed on the manufacturer.
I may be dumb but I'm not that dumb. Nowhere did I mention mm, you are reading things into my post that I never said.It is the percentage of the width of the tyre, not a 'mm' measurement ...
I never said you HAD mentioned mm, but its an obvious assumption for those who don't know how tyres are coded, hence my posting the info.I may be dumb but I'm not that dumb. Nowhere did I mention mm, you are reading things into my post that I never said.
I've never weighed any but I read it somewhere a few years ago. Racing wheels will be lighter of course, but styled alloys can be significantly heavier than steel depending on the design.Of course they aren't heavier.
The whole point of alloy wheels is that they are lighter.
Yes .... but. The 15" alloys so save 4kg compared with the 15" steel. But, according to Hymer, the 16" steels add 16kg to the 15" steels but the 16" alloys only add 4kg to the 15" steels.On Hymers 15" wheels the Alloys are 4kg lighter but with 16" wheels they are 4kg heavier.
Confusing ain't it.Yes .... but. The 15" alloys so save 4kg compared with the 15" steel. But, according to Hymer, the 16" steels add 16kg to the 15" steels but the 16" alloys only add 4kg to the 15" steels.
So the 16" alloys are 12kg lighter than the 16"" steels, or so they say!
Must add this was for the 2015 models!
Yup ......Confusing ain't it.
I think that's an error in their printed information (one of many).On Hymers 15" wheels the Alloys are 4kg lighter but with 16" wheels they are 4kg heavier.
I think Peter pointed it out correctly the weights are based on 15" steel wheel so 16 alloy are 4kg heavier than 15" steel but lighter than 16" steel.I think that's an error in their printed information (one of many).
Is this another IQ question? My head hurts!Yes .... but. The 15" alloys so save 4kg compared with the 15" steel. But, according to Hymer, the 16" steels add 16kg to the 15" steels but the 16" alloys only add 4kg to the 15" steels.
Yes, maybe I misunderstood that bit of the spec when I read it.I think Peter pointed it out correctly the weights are based on 15" steel wheel so 16 alloy are 4kg heavier than 15" steel but lighter than 16" steel.
It may just be that manufacturers adjust the speedo to suit the size of wheel provided but I doubt they touch the transmission. I’d stick with the smaller wheels for more torque and to be easier to remove. I don’t think the other benefits would be noticeable, other than thinking you’re going faster and so avoiding the chance of a ticket.
Or you could just look at Continentals data sheet, it's in there.Put these together and you can calculate the (unworn) circumference of the wheel.
Is everything going to be so illegal we cannot pass wind without being risk assessed.
