What's everyone's thoughts on changing brake fluid? Just had a reminder for my service and mot and in addition they are suggesting a brake fluid change, is it really necessary? MoHo 8 years old.
You only find out about the lowered boiling point whilst travelling down a steep hill. When even using engine braking correctly fails to slow you down you'll wish you had changed it.When did changing brake fluid become part of the service schedule, and why?
When I was earning a living as a mechanic in the 60's 70's and 80's it was just an item that was topped up.
I can understand if you do a lot of very heavy high speed braking, the fluid could boil.
I know people with 20/30 year old performance cars that have never replaced the fluid.
Funny that, couple weeks back on Skye we had a problem on a short steep wet road, the wheels started to spin and the traction kept cutting in with a smell of burning rubber. We ended up reversing and going the other way. The problem was there was a sharp turn on the single track road so we were in second going up, and the van wasn't having it.I normally get mine changed at 4 years.
Last year I had big problems with the Traction control cutting on hills on wet roads and slightest bit of gravel so bad at times the van would stay stationary with a nice burning rubber smell.
Also had problems with ABS cutting in when shouldn't.
Fiat dealer charged me loads of money to tell me there's nothing wrong.
When I had a service at my local independant I got them to change the brake fluid.
Van has behaved perfectly since I can only assume contamination in the fluid caused the problem.
I used to use silicone-based fluid years ago. It is not without problems though: any water that does get in does not mix with the fluid and sinks to the lowest point - normally the rear cylinders or front & rear callipers on an all-disk set-up where it does what water does in contact with aluminium or ferrous metals.It is a good idea as posted above to change due to it being hygroscopic , and the subsequent boiling point lowering. Further reason is that can also lead to internal corrosion of the braking components over time .
DOT 5 brake fluid is not hygroscopic and therefore does not have to be replaced due to the increasing water content. As a rule, silicone fluid should be used only to fill systems that have not been previously filled with glycol-based fluid.
But the Problem with DOT 5 silicone fluid is it’s more viscous and doesn’t flow very well so can make bleeding the system more difficult, plus it still gets water ingress, but this isn’t absorbed by the fluid so it migrates to the lowest part of the system ( callipers/ cylinders) exactly where the most heat is generated,It is a good idea as posted above to change due to it being hygroscopic , and the subsequent boiling point lowering. Further reason is that can also lead to internal corrosion of the braking components over time .
Reading the thread reminded me that I didn't notice any reference to the Brake Fluid having been changed when we bought Brunhilde at the end of April. I was fretting about having the service done, getting the cambelt changed, and mithering about the age/condition of the tyres, that I never gave the Brake Fluid a thought ... Doh!Thanks for all the interesting and informative comments, I will be getting it replaced along with the service/mot in November
I’m surprised to read that. I was in the garage trade about 20 years ago and don’t remember brake fluid changing being a frequent item.I think the best answer is to follow the vehicle manufacturers recommendation for both the service interval and the fluids to be used. They designed and built the vehicle and probably know best!
All the vehicles I have owned in the last 20 years have had a 2 year frequency for Brake fluid change specified by the manufacturer on the service schedule.
There is also a specification for the fluid to be used in the brakes, set by the manufacturer. I would suggest that using different fluid than the recommended one would be rather risky. Think about it, using a different viscosity of fluid in your breaking system!
Bob.
It might be to do with litigationI’m surprised to read that. I was in the garage trade about 20 years ago and don’t remember brake fluid changing being a frequent item.
Mine was about £40 on the service bill, not too bad especially as it cured all my traction control problems that a Fiat dealer didn't have a clue about.My garage is charging £49 for brake fluid change so better to be safe than sorry I think.
Can you expand on this, I thought wheel cylinders were on drum brakes, not many will have these ?I would suggest if you have paid for a fluid change check the wheel cylinders have at least a drop of fluid showing they have been used
Back then most cars brake pipes were uncoated steel and by four years old were getting pipes replaced for MOT and therefore brake flued got replaced.When did changing brake fluid become part of the service schedule, and why?
