Hope someone can help, our key fob has decided to stop working, it will open/ unlock but not lock doors, I have put a new battery in to no avail.
Our van is a 2013 AT Apache.
Any advice please.
If it’s just the habitation door it could be a broken wire - there was a flexible sleeve containing the wires running between the body and the door in our old van, and it doesn’t protect the wire very well.
The hab door on my burstner (2016) stopped working on central locking, near the bottom (hinge side)are a set of contacts, they just need a little rub with emery board to clean them.
Hi Barney23.
Make sure ALL doors are properly closed, as it won't central lock unless they are..
It is some times hard to see if the cab doors ARE closed all the way.
Mitch. ( AT owner )
