Good point PJ, a whole area we haven't even mentioned yet. In the same vein, the timber wall battens should be drilled, as with a new installation. I think I would just cap the slots DBK has cut, like we used to do with floor joists.
agreed.
Any cable less than 50mm from the surface of the wall (with the exception of stud walls where the cable SHOULD pass, protected or not, through the centre of the studwork) MUST have suitable protective armour in any case.
While the type of protection isnt specified, idealy this should be a steel plate so it cant be drilled with a normal masonary/wood drill bit at a future date.
That said, we use oval plastic tubing for socket and switch drops which is generally just below the plaster surface but the diagram rules are always followed...ie: no diagonal chases.
Even an electric cooker cable is chased down from the switch then across to the outlet.
