Cassette toilet access (2 Viewers)
Campercol18
Hi all, i'm new to the forum. I am nearing the end of a campervan conversion using a 2013 Transit Jumbo XLWB panel van. I am about to cut the exterior hole for the cassette toilet but the shape of the transit means the access door frame will not sit flush to the side of the van. I have seen in magazines where others have used a moulded infill for the gap left but I can't track one down. I emailed Thetford who replied that they know what it is but that they don't manufacture them. Does anyone know what they are called or where I may buy one? Any help will be much appreciated. Thanks.
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
Sep 26, 2013
4,169
5,154
Market Rasen
Since 2003
I don’t believe that anything like that is available, I also raised mine a bit to avoid the plastic trim on the Boxer and just filled it in with black Sika.
Dec 12, 2010
5,409
21,557
Cumbria
On a friend's Renault Master Devon conversion, you accessed the cassette from inside the van, maybe not the most elegant of solutions, but sometimes you have to think outside the (thunder) box ?
Campercol18
Campercol18
Hi, thank you for your advice and welcomes. I will try John Cross first but if no luck i'll go with the sika. I did consider accessing the cassette from inside but apart from my Mrs not being keen there isn't enough space between it and the cooker opposite unfortunately. Appreciate everyone's help
32,646
66,526
Have you thought of making your own infill by using a rubber/silicone etc cover strip (eg windscreen wiper rubber surround, infill strip for lockers, window trim etc) and trimming it to match the contour? Obviously still make it watertight first with sealant but then this could be put over it to make it look better.
Hollyberry
5,518
42,265
New Forest.
None.
4yrs
I had the same in mine. It looked perfectly OK and as the cassette is sealed and perfectly clean on the outside it didn't make any difference sliding it out inside the van.
