Note: This feature currently requires accessing the site using the built-in Safari browser.
If you bought your van new, the dealer could have ordered an upgrade plate from Carthago at a cost, ours was £160 extra, only wish it was to get us to 4500KG's but ours would not go to that limit as a C Tourer on the lighter chassis.My C line has the same plating as yours but the V5 states a MGW of 4250kg not 4500kg. Does anyone know why this is the case?
I would take photos of the VIN plate CLEARLY showing the 4500kg plus photos of the number plates and van so they can clearly see the number plates on the van then send a covering letter, the photos and V5C to DVLA explaining the discrepancy.I am the second owner. I would like to know what the legal position would be were I to be pulled over for a weight check, given the plate on the vehicle clearly states a MGW of 4500kg.
Our dealer had to order a new certificate of conformity at 4500kg as the one that came with it was only 4250kg
Don’t panic, don’t panic!Also been reading about payload and am now worrying a bit about this should I be ok at 4500kg for a carthago c line model
Maybe Carthago plated it at that weight ?My C line has the same plating as yours but the V5 states a MGW of 4250kg not 4500kg. Does anyone know why this is the case?
You'd have problemsI am the second owner. I would like to know what the legal position would be were I to be pulled over for a weight check, given the plate on the vehicle clearly states a MGW of 4500kg.
But was that what Carthago plated it at ? There should always be 3 plates, if an Alko chassis , otherwise 2.Our dealer had to order a new certificate of conformity at 4500kg as the one that came with it was only 4250kg
But there should be a third as above.This is the plates on my new carthago
Hi Geoff, nothing surprises me, how about this one also, Carthago apparently charge their dealers £60 each year for the Black sticker that has to be placed inside the service log book!Les
That is a con.
I asked N&B for an uprated plate for our secondhand Arto for 3850kg (which is what they were designed for, but downplated by the dealer) and was sent one FOC.
Geoff
There’s nowt free with a Carthago.Les
That is a con.
Geoff
Richard.
