- Jul 16, 2017
- 35
- 37
- Carthago I 141
- Had one 15 years ago, Globestar for last 3 years and now an A Class
I have a brand new Carthago C-compactline Integrated 141 (1st Sept) and am having issues with the vehicle battery voltage. A Phantom alarm and tracker is fitted and the phone app shows the voltage of the vehicle battery.
After driving for over an hour the voltage shows 12.9v. Then I plug into electrics on site and steadily the voltage drops to 12.4v after 12 hours. A few times it has gone down to 12.1v after 36 hours without moving. Am I right in thinking that 12.6v is what I should expect to be normal?
I understand that the smart charging system should charge both the leisure and vehicle batteries. I also understand that the alarm/tracker may be causing a parasitic drain on the vehicle battery. Even if the parasitic drain is considerable, surely being hooked up to the mains should be able to cope with that and keep the vehicle battery at 12.6v?
I have also tested the voltage with a multimeter to check if the phone app is accurate, and I get the same voltage readings.
The control panel has a row of led's to show battery state and the leisure one always has 4 green lights when plugged in but the vehicle one only shows 2 green lights.
