Carthago Malibu Charming 640GT 2019 Model (1 Viewer)
jean1913
11
5
Guernsey
Malibu Charming 640
I’m a newbie
Hi I've just joined Motorhomefun and looking for other owners of the Malibu campervan to ask some questions please. Hope there are others like me out there! Thanks Jean
AndyPK
5,004
13,833
Cirencester
None……..!
Motorhoming since 2015......
Welcome from Ciren! (y)
Jul 6, 2016
1,547
1,264
West Sussex
Carthago Chic A clas
Since 1990
Welcome to the forum. For your information, there is a UK based Carthago owners club with quite a few Malibu members.
Use your first free 5 posts wisely :giggle:
bigtwin
5,219
9,896
Derby
Concorde
Since 2006
Very little of the equipment in your van will be specific to your model of van. Furniture aside, it’s likely that all of the equipment in your van will be common to other models and other manufacturers.
Go on then, fire away.
Ian
Reactions: f6c
Nov 9, 2015
366
451
Shenfield, Essex
Carthago Malibu PVC
35+ years mainly in VW's
Hi Jean
Welcome. I have a 2016 Malibu DB2 600 which I have had from new. I also am aware of some other Malibu owners on the forum, so fire away with your questions and I’m sure we can find some answers for you (y)
Regards
Trevor
J
jean1913
11
5
Guernsey
Malibu Charming 640
I’m a newbie
Ian
Thanks for responsing
J
jean1913
11
5
Guernsey
Malibu Charming 640
I’m a newbie
Ooops pressed wrong key.
Thanks for being in touch.
I am having issues with my Truma CP Plus Heating Control. I keep getting a Flashing warning E517H. Despite giving the system 15 minutes to reset, when I begin again I get the same issue. Its driving me mad.
Everything else that should be on is and I can't get beyond this flashing warning. I am driving to Portsmouth on Saturday at 0400 and when I arrive will need some heating whilst having to wait for to board the ferry. Any ideas please? Thanks
dodfloss
211
520
beverley yorkshire
dethleffs eighty a class
2 years
[/https://www.caravanmotorhome.org/motorhome/truma-combi-boiler-fault-codes/?fbclid=IwAR1P3vAS593jjtU1hn8j1W-7Sz7sFJlfHuALMHw1Diegnqjxw_FNZj4rXOk
Compactliner
204
184
Carthago Compact 138
11 yrs
from the above table...
517Combustion air infeed or exhaust outlet blocked.
Gas reg. faulty.
Inspect openings for obstructions i.e snow then remove.
Inspect then replace regulator.
  • Nice One!
Reactions: f6c
J
jean1913
11
5
Guernsey
Malibu Charming 640
I’m a newbie
Hi Jean
Regards
Trevor
Hi Trevor
Not used to how this site works, but have an issue with the Truma Control for the heating. If I post my question to you do others see my question too?
Jean
J
jean1913
11
5
Guernsey
Malibu Charming 640
I’m a newbie
etc and then the control comes up with an error E517H. I've tried waiting the recommended 15 mins and starting again but to no avail. I need to know that this will work for tomorrow evening or I will be frozen!
Help please!!
I have a problem getting the Gas heating to work on the Truma CP Plus Control panel. I have everthying set up, gas on etc
Compactliner
204
184
11 yrs
yes, as above, basics first....does the hob work on gas? the error suggests a possible cause might be a duff regulator, definitely not unheard of...with a failing regulator its still possible to have the hob work but for it not to provide sufficient gas for the heater to work.
is your van new, or at least under warranty? if youre in Gurnsey, where did you by the Malibu?
try calling Southdowns (Portsmouth) or Reliance nr Chichester and explain the issue....they will be bookd for months but may have someone free for a few mins to test/change the regulator.
does it work on EHU?
is it possible to use sites with EHU while trying to get a local (French/Spanish?) dealer to help sort the gas issue?
good luck.
Nov 9, 2015
366
451
Shenfield, Essex
Carthago Malibu PVC
Hi Jean
I see that you are now read only as you have used your 5 free posts. To post more, you will have to subscribe (see Link Removed ) and pay £15 for a year. As you can see, there already have been a number of suggestions for you.
If your gas taps and cylinder are turned on and the hob and fridge work ok, it may just be something simple like the cylinder is low on gas (there may be sufficient for the hob and fridge but the Truma draws quite a bit more gas when running)
Trevor
Jun 8, 2019
4,931
18,759
Bexley Kent
Given up Motorhoming
May 2019
Hygiene (sorry couldn’t resist it). Greetings peeps welcome from West Kent
