Attachment does not open.
Guess it's the Compactline from what you've described with island bed.
Carthago claim a payload of 575kg on a 3500kg chassis. The payload figure is based on carrying only 20 litres of fresh water. Anything subsequently added to the basic spec (awning, solar etc) will deminish the payload.
If you plan travelling with a full water tank and cram the garage with stuff, your payload is likely to be quickly eroded. The island longitidinal bed is nice but it does take up valuable space from the main habitation area. My van is also 6.99m long (4250kg MAM) but with a transverse bed over the garage. This gives an acceptable living space.
If you have a C1 licence the chassis can be uprated but it will cost....assuming it's already shod with 16" wheels.
Best advice is to get the van weighed PRIOR to purchase so you can judge what spare load capacity is available. As a minimum, you need 2 weighbridge readings, one with both axles on weighbridge and secondly with just the rear axle on weighbridge. The front axle weight is the difference between the two readings.
Yes the wife wanted island bed , with separate shower and toilet , and the only one available , also the company are giving crazy money for my Grand Canyon !!!Attachment does not open.
May have been registered in 2020 but its not a 2020 model year, gives you something to negotiate with.First registered July 2020 on log book and 20 on Reg plate ??
Tell me more as I am new to Carthago models plsNow you have put a photo up that is not a 2020 model , it's either 2018 or 2019 not sure which year they updated them.
Thanks Lenny , I am putting a Vespa in garage and 2 e bikes and all the rest of the gear!! It all fits in the smaller fiat Grand Canyon, also I put air assist on fiat much betterMay have been registered in 2020 but its not a 2020 model year, gives you something to negotiate with.
Actually nicer than the newer ones.
yes I’ve seen them ones but not a lover of white !!!Main change is white body with different logo.
I think you may be on a limit, but do the home work before you part with your cash.Thanks Lenny , I am putting a Vespa in garage and 2 e bikes and all the rest of the gear!! It all fits in the smaller fiat Grand Canyon, also I put air assist on fiat much better
If its 3500 you will need to uprate to 3850 kg to get a useable payload.
Sorry to be the bearer of bad news but I don't think you have a chance of being within weight with a motorbike in the back. Our C-Tourer on a heavy chassis is 2500kg on the back axle with a 170kg KTM in the garage, "all the other crap" and full fresh water. We have headroom as we up-plated to 2700kg on the rear and 4800kg max but I think the Compactline versions are just to lightweight. And they are all over the weight claimed by Carthago.... by some margin. Great vans, just heavy.Thanks Lenny , I am putting a Vespa in garage and 2 e bikes and all the rest of the gear!! It all fits in the smaller fiat Grand Canyon, also I put air assist on fiat much better
No chance unless it's on the 4259kg Maxi chassis even then you may have to upgrade the rear axle.Thanks Lenny , I am putting a Vespa in garage and 2 e bikes and all the rest of the gear!! It all fits in the smaller fiat Grand Canyon, also I put air assist on fiat much better
I agree that a lot of the base weight is at the back but my i143 Compactline has a great deal of underfloor storage between the axles and I have managed to stow a lot of the heavy stuff such as tool boxes a good way forwards. I think the i144 is similar.Carthago layout is naturally "rear heavy" (water tanks, garage contents etc). Little opportunity to shift loads forward.
We also opted for cupboards instead of the drop down bed. Looks great without the bed and the extra storage at the front end is very handy too if you are trying to keep the rear axle weight down.I've got the front cupboards in lieu of drop-down bed which saves a bit of weight.
