OldAgeTravellers
When removing all batteries and connections prior to fitting my BMV702 battery monitor, I came across this fuse melted in the engine battery box under the floor. It's a 2012 Fiat chassis Hymer B614. The Hymer book says that the 50amp is for the transformer/rectifier which I presumes means the EBL and that the yellow 20Amp which is melted is for the fridge but I got the impression that it was for the engine battery charge when on solar or hookup, when my engine battery went flat once that fuse was blown. When I replaced it the engine battery started charging again from the EBL. They also say the 50amp one in the habitation battery box is for the transformer/rectifier, would they put one on each end? I thought the Fridge was controlled by the EBL101. Unfortunately it has destroyed the fuse holder (Dirty contacts perhaps caused heating, although I replaced the fuse a couple of months ago so it should have cleaned them a bit). There is nobody within 50 miles even if I could get one. Anybody see anything wrong with the bottom picture setup? At least till I can locate the proper fuse holder.
Also if this is the engine battery charge fuse, so very important but buried under carpets etc. would it be worth putting an LED in a visable position across the terminals to show when or if the fuse blows as the first indication is a flat engine battery which can be very expensive.
Thanks for any input.
