Can I change the plug? (1 Viewer)
BreweryDave
3,495
10,541
Alvor, Algarve
None now!
This is the mains plug which powers my android IPTV box.
Can I simply change the plug to a 12v cig lighter type plug and expect the device to work off my 12v system??? It's says the output is 5v and 2 amps.
I think so, but any experts opinions???
Tia.
D
Deleted member 29692
No you can't.
That's basically a transformer plug.
5V output means that the TV box works at 5V. Is it a USB connectoror something like that?
If you cut the plug off and replace it with a 12V one you will deliver 12V to the box instead of 5V.
The results will be somewhere between it just not working and it blowing up the box.
Glandwr
Banned
Jul 10, 2014
1,057
3,301
the Berwyn Mountains
Hymer S740
since 2009
Afraid not its a transformer as well as a plug and 5 volts not 12. You could run it from a usb plug but would need to be careful about polarity
Apr 21, 2009
546
34,642
East Cowes, PO32 6RU
Caravan
Caravan since 1970, motorhome or RV since 1999 then back to a caravan in 2017.
The output from that plug is 5 volt, if you just connect the cut lead to a 12 volt supply you will be sending over twice the voltage needed to the appliance and would probably 'fry' it. Subject to the appliance working off Direct Current from a battery rather than Alternating Current from the mains you could 'drop' the voltage from 12 to 6 (which might not 'fry' the appliance) quite cheaply. Personally I would prefer an inverter solution.
Wish I could type faster!!
Minxy
32,489
66,017
E Yorks
Carthago Compactline
No ... sorry!
Think of it this way, you are powered by 5v and someone sticks 12v up your jacksie ... would you be happy! :eek:
Steve N Tracy
1,222
3,705
Southampton
4 Years
A 12 volt USB cigarette lighter converter will be a 5 volt output you can by them with a 2 amp current output.
D
@BreweryDave
Dave, what's on the other end of that lead?
If it's a standard connector then replacing the whole lead with the appropriate USB lead and using an adapter as Steve N Tracy suggested it going to be the best solution.
Cutting the plug off and replacing it with a USB plug is not an option unless you really know what you're doing.
D
I guess it's a no then !!!
This is the other end....
This is the sort of thing you need.
That won't be the right one. You'll need to measure the round plug on the end and find one to suit, or better still go to somewhere like Maplins.
Once you've got a lead that fits you need one of these or similar and you'll be sorted.
Kevc
58
27
Gloucestershire
Compact Leisure vehicle
Since 2011
Either need to measure and purchase online, but if nervous take the existing lead in to Maplins, I am sure they will be able to help you
Good luck
Kev
Reactions: DBK
Nov 18, 2011
11,857
42,497
Planet Earth
A van
Over 25 year's
Tia.
:Eeek: Do i sense the smell of burning plastic and electronics no Dave NO DONT DO IT its 5v out put you will kill it:crying:
nill
Sep 17, 2017
5,335
9,945
Birmingham, UK
A-Class
2 amps is quite high for USB. If you just connect to the normal power pins of a USB output, don't you only get 0.5A? Doesn't the charger need some QuickCharge intelligence at the other end to get it to kick up to higher outputs??? Not sure.
Reactions: DBK
Glandwr
Banned
Jul 10, 2014
1,057
3,301
Hymer S740
since 2009
Usb sockets now supply up the 2.4 amps they will have the rating on them
Sep 17, 2017
5,335
9,945
Birmingham, UK
A-Class
I know they can supply 2.4A, but do they need to be sent some secret message down the data lines to activate it? Does the device on the other end need to talk 'QuickCharge 2.0' or similar... 'cos a simple 2 pin cable isn't going to do that.
Glandwr
Banned
Jul 10, 2014
1,057
3,301
Hymer S740
since 2009
You are right but the cable shown will only send a constant 2 amps exactly the same as the original transformer as long it is plugged into a 2 amp or higher rated socket. It's the device (phone etc) on the receiving end that does the controlling in the system you describe. This device fed by a simple 2 wire jack obviously has no need to do that.
Alistair33
1,079
3,258
North Yorkshire
Hymer
None
@BreweryDave
I managed no problem with a USB plug wiring diagram for the internet, a solving ion, and a usb plug, also from the internet and luck to convert a Katcher window vac to 5v........
Sep 17, 2017
5,335
9,945
Birmingham, UK
A-Class
I thought the way USB worked was that it was 0.5A max unless the device plugged in to it was smart enough to ask for more? Although it was possible to fool it by putting a simple resistor across the data pins I think???
Aug 18, 2014
23,539
131,313
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
These day they can be rated at larger amounts. doubles used to be 0,5A for each socket but if only one was used then you would get 1A. Ihave some rated at 3,1A on one section & 1A on the other.
Glandwr
Banned
Jul 10, 2014
1,057
3,301
Hymer S740
since 2009
That applies, or did, to usb outputs from a laptops or similar. I think we are talking 12 volt adaptors here are we not?
DBK
17,969
47,804
Plympton, Devon
PVC, Murvi Morocco
I think historically 2A was seen as high but that's the sort of rating you need these days to charge a typical tablet. I've seen some adaptors rated at 3A. AFAIK you can't damage a device by connecting it to a charger higher rated than it might originally have come with. As the batteries are charged the charging current will tail off naturally.
