can I add a secondary solar system? (1 Viewer)
biglamin
21
5
yorkshire
coachbuilt
since 2007
my 2014 autosleeper has an installed solar system - don't know what size as it was there when we bought the van. the dealer reckons it could be an 80w as this was an upgrade offered at the time the van was new. We have two 110 leisure batteries which don't seem to hold their power - especially when compared to our previous van when 130w kept them fully charged permanently
anyway,can I simply add an independent solar system directly to the batteries, but in addition to the existing system going through the seargant control? I thing this system allows only for a max 120w of power
Nov 18, 2011
11,862
42,816
Planet Earth
A van
Over 25 year's
Why not i did just hooked up another one to the existing system
as long as it is secure its not hard to do with modern materials
i will be adding another one when i get one cheep enough
bill
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
Amazing thread title - I thought for a minute God had written it.
Maybe have a word with Prof. Steven Hawking?
B
biglamin
21
5
yorkshire
coachbuilt
since 2007
lol magicsurfbus!!!!
cheers Wildbill but I don't want to add to the existing system. want a bigger panel than this allows
R
Robert Clark
Yes, you can have multiple systems, connected via their own controller.
This is now Vanbitz connected my two solar panels, each with their own controller
Nov 18, 2011
11,862
42,816
Planet Earth
A van
Over 25 year's
look like a new start then new controller but existing wiring could well be utilized so no hole cutting or drilling to do
would be interested in your old on when you do up grade
bill
funflair
19,305
30,073
Guisborough
MORELO palace
since 2012
Two systems on ours, no problem, but both go straight to batteries.
Martin
two
Aug 4, 2011
4,901
4,571
West Midlands
A-Class Fiat
Two independent systems are better than one, due to resilience.
andy63
4,672
15,017
south shields
None
since 1990
This keeps coming up... it is obviously possible and works but I think it needs a bit thought to make sure you get the best from both systems..
Not a problem if the batteries are loaded and both systems will feed into it.. but I keep thinking it' possible for one system not to contribute if the controllers are miss matched and the batteries are only taking a charge...
The controller with the higher voltage will do the work, where as
If it was one system the batteries might benefit from a slightly higher charge current ... most probably splitting hairs but thats' what I think...
I'll be put right shortly I'm sure..:D
Andy.
Oct 8, 2014
1,630
3,009
Wiltshire
Autotrail Excel 600B
Previous VW Camper + Caravan
It isn't an aeroplane. Or a spaceship :D
Aircraft often have "triplex" ( ie 3) systems monitoring sensors and instruments. If you have two sensors monitoring something, and get different results, then which one is right? A modern triplex system will allow a computer to determine if one of the sensors is faulty.
Minxy
32,624
66,461
E Yorks
Carthago Compactline
Before going down the route of installing more solar panels why not check the state of your actual batteries ... if they are not holding charge as well as your previous MH then it may simply be that they are stuffed and need replacing.
funflair
19,305
30,073
Guisborough
MORELO palace
since 2012
Andy.
Andy you are right that one controller will start to cut back when it sees that the voltage is high enough, but at this point a single controller would give the amps to maintain charging voltage, just my thoughts.
Martin
