Can Glass Cover Hinges (1 Viewer)
Sep 12, 2020
43
22
Compass Avantgard300
Since June 2020
We have a 3 burner Can hob with a glass lid. This hinges up but sits at 90° and is prone to dropping if the motorhome shakes. I've tried to tighten the hinge pivots but don't want to run the risk of being too tight and the glass breaks. There doesn't seem to be any springs in the hinges to keep the lid vertical. Any thoughts please people?
Silver-Fox
9,033
26,657
Cheltenham Spa
Rapido
im a not so newbie
Can you fabricate a simple catch to hold it in place and screwed to a wall?
M
Sep 12, 2020
43
22
Since June 2020
Sadly not as the window blinds are only a few mil away. Any protrusion into their space would stop them moving.
Oct 12, 2009
9,691
21,701
A Class N+B Arto 69GL
Since 2009
Our glass cover has a metal plate attached to the side of the glass with a hinge so when the cover is open one swings the plate at right angles and it rests on the bit of worktop so holds the cover erect. It also acts as a heat shield for the adjacent wall. The plate stows into two slots in the cover hinge at the bottom of the cover before closing.
TheBig1
17,160
40,927
simply glue a small neodymium magnet to the lid and another to the blind surround. Keep it simple and things work as they should
Nov 18, 2022
320
444
Nottingham
Murvi Morello
Since 1989
Good principle but if a similar 'plate' is not available how about a simple metal rod like many vehicles still use to hold up the bonnet when opened? It would need some kind of hinge glued to the glass (I love gorillas!! 😉).
Or a shelf bracket that's not fixed to any part of the cooker but to a 'U' shape channel that you slip onto the side of the lid when it's 'up' such that the bracket points forward from the lid, near the bottom, and rests on the worktop beside the hob.
Bracket & U channel available from your favourite branch of B&Q or similar.
I know what I mean but it's not easy to describe in a few words so feel free to message me if you need a diagram!
