Can anyone identify the make of this connector? It is connected to my leisure battery on an Autotrail, there is a spare connector I would like to join to.
From Sargent Controller to Leisure Battery, I am assuming this would allow connecting a second battery.Out of interest what are those cables connecting to? I assume something that only takes a low current.
Thanks, yes that will be the alternative if I cannot find the connector type, or it is prohibitively expensive.Obviously you could fit a new male and female connector if all else fails.
Hard to tell what size the cable is. 2.5mm tri rated is 30 amps, probably more than the current rating of the Sargent unit.those wires look far to small to connect a second battery too
They only need to carry a maximum of 20 amps, indeed that is the fuse size fitted, and the cables are more than capable of handling that. Charging or discharging a LA leisure battery at more than that doesn't do the battery any good.those wires look far to small to connect a second battery too
Only get 10 amps out of a standard Sargent unit so plenty good enoughthose wires look far to small to connect a second battery too
This may be what you need.From Sargent Controller to Leisure Battery, I am assuming this would allow connecting a second battery.
I should have read further before I posted!I think this is what’s needed.
Funnily enough that is exactly what I did this afternoon with the identical wiring harness on my Benivan - chopped the wires a few inches past the plug (on the battery side) and reconnected with Wago connectors. Might as well make sure you get the higher current (32A) versions, even though the fuse by the battery is most likely 20A.I'd be tempted to chop them off and use Waco connectors the ones that can be easily swapped over.
Wago Connectors | Wago Electrical Connectors | Screwfix
Buy Wago Connectors at Screwfix.com. Join electrical wires quickly and safely. Maintenance free. Trade trusted. Click and collect in as little as 1 minute.www.screwfix.com
Far too small for that.From Sargent Controller to Leisure Battery, I am assuming this would allow connecting a second battery.
That's why I rarely charge from the Sargent charger, and rely on Solar and B2B, with suitably rated cables.Definitely the battery harness - I was disconnecting an identical wiring set up today. The wires are 2.5, maybe 3mm2, fused at 20A. It all works, but you're not going to be running anything heavy duty from it, or charging it rapidly!
cheers,
Robin
