Lucky
- Nov 9, 2019
- 532
- 1,057
- Sunlight Cliff 600XV
- Since 2016
Personally I doubt that air assist can SOFTEN the ride of a motorhome although it might mask the effects of worn leaf springs and/or dampers. What do you think?
My reasoning is that the softness of suspension through its normal range of travel is dictated by the spring rate (which is not changed when air bags are fitted to replace rubber bumpstops).
Similarly original fit dampers control wallowing and air bags won't dampen the rebound of the spring.
My conclusion is airbags might mask the effect of worn suspension, and definitely will have a major benefit once the suspension travel is consumed (you'd otherwise be hitting the bump stops) but is it being oversold as a panacea to cure all the ills of knackered original equipment?
Personally I fitted air assist to be able to increase ground clearance when accessing my driveway.
I'm no engineer so I'm looking forward to informed input.
