Camping without hook up (1 Viewer)
Sep 23, 2007
1,710
1,970
Leicestershire
4 and many as a tugger
Stopped on a CL a few years ago and never moved for 7 days. No solar, only the TV on day six objected to the low battery. That was just one 100amp battery.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
With the pack fully charged, if I was to connect it in parallel to a flat/depleted Habitation battery, would I get a short term power reserve?
Without damaging the electrics in the Habitation?
Sorry if it's a stupid question.
You would and Yes it would be safe to do so. But it would be very short term. Not a stupid question :giggle:
movan
21,492
120,753
Moving around
Burstner
since07
There's no need to rub it in!:swear2:
Just 'cause you're out dining with a different young toyboy every night!o_O;):giggle:
Ha. Wouldn' t have a clue what to do with one other than invite his granny round for a girlie chinwag. :)
Just quick question, which may also help OP... since the 'something'... (I'm not technical)... switches off automatically if the 12v leisure is full and as is the engine battery, would this damage the solanoid because you havn't turned the solar panel off before the 12v disconnects?
May 29, 2016
1,038
1,406
Hampshire
Carthago C-Line
Since 2016
If its TV usage that is worrying you, then how about getting one of the Cello battery TVs? They say the battery will last for 8-10 hours viewing, which in our experience is pretty accurate. Make sure its fully charged at the start of the trip and it'll should last a few days without needing to be recharged - might take some of the pressure off your leisure battery.
The Lobster
321
325
Borders of Scotland
Bürstner A576
Still getting started
Biggest difference to routine power drain for us was swapping all the bulbs out for LEDs... although it's sometimes hard to fit LED bulbs that have built-in RF interference suppressors in the same space, so I fitted some clip-on ferrite beads on the power leads close to the bulbs and that did the trick. Of course we're enjoying long summer evenings right now, so less of an issue perhaps.
Other than TV, lighting is the only "essential" we can't run on gas - and actually, TV isn't necessary if the weather's fine. When our grandkids were little we would keep some of their favourites downloaded to a USB stick ands plugged in to the TV (in case we were out of broadcast range) so they could watch one before bedtime story - i.e. keep to their routine. Made everyone's life easier. So actually a second gas bottle is more important to us than a second battery.
I
Mar 18, 2013
22
24
Glossop
Autotrail Tracker FB
Since 2013
Thanks for that, the Cello range looks good for when the existing tv expires, but I'm not intending spending much more time with the little ones on non-ehu sites to justify that expense just now 🤔.
I
Mar 18, 2013
22
24
Glossop
Since 2013
Thanks, yes we're all LED throughout, plus some extras I put in. I've a new 13kg gas bottle on board and one of those normally lasts me about a year, though 4 days running the fridge and heating the water will probably make a difference this year 😭.
funflair
19,341
30,214
Guisborough
MORELO palace
since 2012
Not sure that I really understand the question Joy, do you? ;) I guess you are just talking about the battery charger disconnecting when the batteries are full and the solanoid might not even be a solenoid but I still think the answer is NO don't worry about it.
Martin
Janp
19
47
Wales
newbie
Battery radio? ? fun finding different stations , battery fairy lights grannies fairy cabin ? solar lights for outside ? some board games? pack of cards ? .... I know Im so old fashioned 😊😊😊
Wiener-dogs201
12
21
East Sussex
Adria
newbie
TV? TV? Luxury item weight wise and power wise. We use a mini projector that is rechargeable via usb port, total weight with screen less than a 20 inch TV and easy to keep running on a power bank. Can use it with a NOW TV or Fire stick device so can also have Netflix, Youtube, the News and catch up tv on it too. Download a few films for the children or yourself on a USB stick too and you have most entertainment covered. As for things like laptops, we use a 17 inch monitor with a micro pc on the back both run off USB and again weight and power consumption is minimal, it can also be used to watch any of the hdmi sticks if nobody is using the PC. Internet is via a pocket router (usb rechargeable of course) with an £18 unlimited data 3G/4G sim card. 250 Watts solar panels and 120Ah leisure battery. A rechargeable small soundbar helps with the audio, guess what, it charges via USB so can be run off a cigarette lighter port with several USB ports and the other stuff charged off the solar controller which also has an inverter with USB ports and an extension lead which has another 4 USB ports.
We are restricted on the weight we can have because getting the vehicle up-plated and gaining a C1 license is not an option so we had to find ways to reduce weight and power.
Roadroamer
21
24
llanelli
elddis 115 coach built
since 1994
A suite case 120w solar panel with built in regulator is the answer!!!! you just use crocodile clips to the leisure battery plus you can always sell it on if you don't need it afterwards
