Camping gaz 907 cylinders
Hull
Autotrail 634
Since 2006
Hi.Does anyone know if it is possible to get 907 bottles refilled rather than simply exchanging for a full one at an extortionate price please?
Not a problem in Portugal, a place near us will fill any, except Portuguese bottles for some reason.
He has even filled 904 and 901 bottles for me, propane though.
You can do what ever you want till it goes wrong or someone grasses you, otherwise crack on
They are just exchange and rather like calor but even more expensive. But popular in France and spain so easy to swap ( good for a back up to a spare camping stove)
Tonks
that is the question i answered.
LPG whether autogas or bottle refill seems to be a problem in some parts of the country.
Gaslow is better than the illegal alternatives.
Tonks
Absolutely, but only if you actually CAN refill them. If some fuel stations won’t allow you to refill your Gaslow 907 equivalent cylinder then going to the expense of swapping to Gaslow is rather pointless. I’ve been looking into it, but so far have had no reasonable reassurance that I’ll be able to refill a Gaslow cylinder which must be removed from the van to refill.
Reply deleted to give it deeper thought as I'm getting myself confused between Gaslow, Gasit and Safefill systems. :rolleyes:
https://chorleybottlegas.co.uk/shop/campingaz-gas-cylinders/campingaz-r-907-refill
This is what the op is asking about (y)
They are not gaslow and not refillable ( legally)
The new gaslow refillable is an R67.as below
Tonks
if you don't think you can fill it don't buy one. I'm just stating it is an alternative. currently I have a 11kg Gaslow and 15kg calor butane to use up, normaly carry a 6kg calor as backup.
when i had a bongo the normal practice was use one or 2 907's. i found i could just fit a 4.5kg kg calor at half the price of a 907(and a 907 spare). To reduce cost try that route as an alternative, depends on space available. Gas availability a problem today!?
A 4.5 kg calor is around £14.50 for an exchange ,expensive for around 9 litres but still cheaper than camping Gaz.
I'm not sure how one would refill the Gaslow cylinder without having the body mounted filler fitting unless there's a connector available to enable one to connect the LPG gun to the Gaslow filler point on the cylinder. :unsure: I know that there's a Safefill connector but would it work with a Gaslow cylinder?
Upvote 1
in the past i've seen one for the job may have been a gasit one.
Apologies for hijacking the thread.
We have a dilemma which hopefully you can help us with.
We pick up our new van in a few weeks. We plan, currently, to keep it for approx a year before our long overdue van arrives next May 2023. During the next 12 months we intend to spend long periods of time in Europe and we are aware of the gas bottle hassles from country to country.
From what we understand the incoming van takes 1 x 11kg and 1 x 6kg gas bottles and the long overdue van takes 1 x 907 Campingaz, it has diesel heating.
The options, as far as we are aware, are:
1. Go through the hassle of changing bottles and pigtails, bottle disposal or lugging the empties around with us. (Have I got that right?)
2. Fit a Gasit underslung system (don’t want refillable bottles). This is expensive and whilst I can take it with me the May 2023 van doesn’t need it.
3. Use 2 x 907 Campingaz bottles. Really expensive to exchange (£37.50 this weekend) but easy to exchange throughout Europe.
Are there any other options, if not what would you advise based on the above? As always many thanks
It’s entirely possible and very easy to refill 907s yourself, very safely, using a donor butane cylinder (NEVER propane).
As for legality, technically, with Calor and similar cylinders, the user never owns them, but is a contracted license holder. It would be a breach of the license to refill Calor cylinders, for example.
The difference with Camping Gaz cylinders is that the user owns them outright, rather than being a licensed holder (as with Calor et al) and there are consequently no license terms to breach. It is extremely easy to purchase all the necessary parts from UK LPG kit suppliers to make a safe transfer kit.
The process is no more unsafe than filling a car with petrol or refilling underslung LPG tanks at the station, as long as basic safety precautions are followed (i.e. the refilling is done outdoors with no source of ignition nearby and the correct measured mass of liquified gas for the recipient cylinder is transferred).
The cost of the assembled kit and the donor cylinder typically pays for itself after 2-3 fills.
In posting the above, I am stating what is possible but in no way encouraging others to do something with which they feel uncomfortable. All the necessary information and safety considerations are freely available online for those who might wish to search for themselves.
As said above I used a hose bought similar to the link below to attach the two cylinders together.
Just buy a French exchange bottle when you are in the eu .Someone posted recently that a 13 kg bottle was around 26 euros and 1 euro deposit from a French supermarket. Cheaper than refillables.
Off to France in a couple of weeks. To use a French bottle, will l need a different gas connection to my current UK propane connector?
