Cambelt or Chain (1 Viewer)
Bertyboy
79
14
Essex
15 years
Hi Funsters,
Have just bought a Pilote 715FJ on a Renault Master nobody seems to know whether they have a Timing belt or Chain. Can anyone tell me.?
Also can anyone tell me the payload on this camper
Thanks Bertyboy
Nov 18, 2011
11,856
42,474
Planet Earth
A van
Over 25 year's
Belt look at vin plate for payload once you have taken it to a way bridge
Max waight minus actual waight will give you pay load
Bill
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
I had a renault master 2.8 2000 reg it had a belt and water pump run off it
138go
3,276
14,612
Carthago 138
Since 2001
There will be a plate somewhere giving you the actual weight limit for each axle. Although you may have a lot of payload you can find it’s unusable if all you can do is stack your bits in a locker or garage. Easiest way is to load it up with everything you will be carrying including wife, bikes, dog, bedding, food, full tank of water, diesel and gas bottles then get it weighed. If the weight on the back axle is over then you have to start slimming. Putting heavy weight at the back furthest from the rear wheels makes them weigh more, it’s all to do with levers. If you go over 3500Kg you need a C1 licence. Driving over the permitted weight can void insurance and cost you a fine and points on your licence.
4,924
11,286
Flintshire
Low profile
since 2010
Go to a Motor Factors and ask them to price either a chain or belt for you, give them your registration number which they will enter into their computer system, this will tell you which one you require in minutes.(y)
obanvanman
721
1,617
Isle of Seil Argyll
Eura Mobil 810 Integra
newbie
If it is a 3 litre I am almost, emphasis on almost, sure it is a chain.
You are going to have to take it to someone trustworthy to confirm it.
B
Bertyboy
79
14
Essex
15 years
Thanks for all the replies it is a 2.5 TDI and have now found out (For anyone's future reference) it is a BELT. Thanks again funsters
19,500
51,185
uttoxeter
ambulance conversion
50 years
And a bugger to do Diy need a special tool to hold all the cogs when removing.
