Cam belt Ducatto (1 Viewer)
Trout bum
567
584
Ayr
Adria Matrix M670SL
Hi motorhome now 5 years old so need to get cam belt changed , managed to get a garage with a good reputation to give me a quote , gave him my registration and engine details , he reckons some types of ducatto engines cam belt kits have water pumps included and some don't , he's going to check once he has the van in, anyone else heard the same thing .
Lenny HB
52,698
147,630
On the coast in West Sussex
Hymer B678 DL
It will have the water pump driven by the cambelt so best to change it, a belt supplied in the kit would be down to the kit manufacturer noting to do with Fiat. It was the X244 2006 and earlier that didn't.
The Dotties
1,872
4,022
Gloucester
In between
Ex Newbie
Yes. Had mine done recently. New belt, water pump, and pulley wheels.
Was advised to get everything done whether it needed doing or not.
The cost of the pump is negligible against the damage a seizing water pump can do. Even changing the pump after a new belt involves a full strip down. Gates are one of the leaders for replacement
That Lenny HB is to bloody fast on the keyboard!šŸ˜„
Trout bum
Trout bum
567
584
Ayr
Adria Matrix M670SL
Thanks Lenny if by any chance it wasn't driven by the cam belt would that mean it wouldn't need changing .
Lenny HB
52,698
147,630
Hymer B678 DL
If not driven by the cam belt it won't wreck the engine when it seizes and easy to change. If driven by the cambelt it's lightly to wreck the engine if it seizes and to change it is almost as much work as changing the cambelt.
You said yours is only 5 years old as I said it will be driven by the cambelt.
glenn2926
3,326
13,619
Gods country
Chausson
newbie hired 3
Hi, just collected my van from the garage this afternoon. Itā€™s been in for cam belt. The garage owner is a mate and he recommended having the water pump done as the strip down to do it later is just about as big a job. Also if the water pump seizes then it can snap the cam belt and kill the engine. He wasnā€™t quite as nicely spoken as this thoughšŸ˜‚šŸ˜‚.
Jan 1, 2017
1,159
2,609
eastbourne
van conversion, Peug
4 years
Hi all, got a peugeot boxer pvc, is there a recommended mileage for cambelt change?
Apr 22, 2013
911
660
Cotswolds
Bailey Approach 625
Since 2011
I have a 2014 Boxer basec Mh and would like to know the answer as well. If it helps my Boxer has a Ford engine.
Many Thanks
glenn2926
3,326
13,619
Gods country
Chausson
newbie hired 3
Boxer with a ford engine is normally chain driven camshaft.
Is that the 2.2 engine? Mines 2.3 and definitely cam belt. I seem to remember the 3.0 isnā€™t a belt .
Aug 18, 2014
23,539
131,310
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Many Thanks
sounds like the Ford 2,2 engine which ,as said, is a chain.
Easy to check.Open bonnet look on the left hand end of the engine if it is a metal cover at top with sealant around it is a chain.If it had a cam belt the covers are always plastic
Dec 24, 2014
9,034
46,438
Hurstpierpoint. Mid Sussex.
Compass Navigator
Ever since lighting was by Calor gas.
:unsure:
For my m/h the belt life/change requirement is clearly mentioned in the service schedule document for the base vehicle.
Nov 13, 2011
1,473
3,485
Lincolnshire
PVC
30 years
Hi Spriddler
I am sure you are right, but so many of these user manuals are so generic that you need a degree to know what is actually fitted to your particular vehicle/device etc
Geoff
Dec 24, 2014
9,034
46,438
Compass Navigator
Hi Spriddler
Geoff
I know what you mean. I was looking to find out how to disable the movement alarm in my new Skoda for when I leave the dog in the car while I pay for my petrol and lost the will to live, so being a pragmatic and simple guy I just don't lock it.
The owner's manual covers petrol, diesel, manual, auto, ownership in a range of climatic conditions, different tyre sizes and a vast range of optional extras but fortunately there's a sticker inside the front cover with my specific engine model/type.
raysalaugh
2,161
4,112
Leyland
AT Delaware
since 2010
Just had a quote for the cambelt and water pump renewing on my Fiat Ducato, Ā£640 because they say it's a big job
all the front end has to come off, radiator etc. Thought it was a bit steep.
Gellyneck
9,132
17,986
Scotland
More than toes wet now!
You should be able to get it for a couple of hundred pounds less than that at an independent.
raysalaugh
2,161
4,112
Leyland
AT Delaware
since 2010
That was an independent, family owned garage but I don't think they are conversant with the Fiat Ducato.
They also said they needed to hire a special tool. If they are going to get Ā£640 out of me they'll need one.:giggle:
Gellyneck
9,132
17,986
Scotland
At that price they might also be needing a pair of pliers to remove the special tool! :whistle2:
I'm sure ours was around Ā£400 a year or so ago.
Lenny HB
52,698
147,630
Hymer B678 DL
Even if your an is an A Class it's a couple hundred over the top.
If they think the front end and radiator has to come off they haven't a clue give them a wide birth.
Trout bum
Trout bum
567
584
Ayr
Adria Matrix M670SL
I have been quoted Ā£395+vat by a local garage it is a big job they reckon 6 hours all going well no broken studs etc.
Gellyneck
9,132
17,986
Scotland
I dropped ours off at 08:30ish and collected at 14:30ish so 6 hours is correct.
Apr 22, 2013
911
660
Cotswolds
Bailey Approach 625
Since 2011
When you say left hand end I assume that the LH side of the MH ie near the air filter. all is metal there with pumps etc. The LH side as you look into the engine bay is more difficult to look at, but tapping it sounds like metal. When should the chain be changed?
Apr 3, 2019
1,470
2,711
UK
Burstner Travel Van
Few years now
Similar price that I paid a few weeks ago.
Apr 13, 2019
545
1,285
Burstner 747-2
since 2010
Mine is a 2003 2.8JTD, took about 5 hrs, no water pump needed as not driven by cambelt. Cost Ā£200, I think that is fair for less than Ā£40/hr
Apr 13, 2019
545
1,285
Burstner 747-2
since 2010
ok, guy was the cheapest quote and a cam belt specialist, sometimes you win sometimes you don't, he did change the pulleys and tensioner as well as the belt
