Hi can somebody tell me how much an empty calor 13kg propane gas
cylinder weighs
cylinder weighs
You must have an old bottle.On the aluminium collar the weight is stamped in pounds and ounces!
cylinder weighs
I dont see how a 13kg cylinder can vary 9.2 kg empty.
Must be some sort of code then, because neither the 13kg or the 6kg bottle I have in the shed appear to have weights on that plate - not anywhere else.Varies , the weight of each one is stamped on them.
Ah - now that might be the code. I was looking for a weight in kgs. Not going out for another look now.On the aluminium collar the weight is stamped in pounds and ounces!
