I also know someone who uses this part, no hoses as it screws onto bottle.<Broken link removed>
Not tried this myself as we have a local calor dealer that has not suffered a shortage, but I do know someone who has used it and seems happy enough.
I’ve seen them but not sure how it works, I’ve got 3 full 6kg bottles and since I only use gas to boil the kettle they should last for a while.I also know someone who uses this part, no hoses as it screws onto bottle.
I personally wouldn’t use it but we have gasit anyway.
I’ve watched a friend do it , it just screws into the bottle. It’s got a gauge or something to stop it overfilling the bottle. Too risky for me but they are happy enough doing it.I’ve seen them but not sure how it works, I’ve got 3 full 6kg bottles and since I only use gas to boil the kettle they should last for a while.
You start filling calor bottles at LPG stations and you risk possibly overfilling<Broken link removed>
I don't think that is correct.It’s got a gauge or something to stop it overfilling the bottle
Not if you know what you are doing...You start filling calor bottles at LPG stations and you risk possibly overfilling
I discovered the main calor distributors in your area are best stocked. Garden centres, camping outlets etc are way down the foodchain for deliveries. Google caller gas bottle suppliers in your county and found the largest outlet.. they seem to be getting supplies first from Calor. Worked for me, i had to drive a bit but hey ho....Everywhere seems to be out including Calor online delivery .
Any suggestions?
I don't agree with this post.Refilling returnable bottles without the 80% cut off is potentially very dangerous. Pressure gauges are meaningless, the pump filling pressure is up to 200psi. I wouldn’t do it and would rather not be parked anywhere near someone who has.
I imagine they use special equipment and carefully calibrated amounts, having properly drained them first. I am absolutely certain they don’t risk overfilling because it would be dangerous, can stop the liquid from becoming gaseous and has the potential to damage regulators. The liquid gas not only needs room for expansion but needs sufficient surface area to vaporise.If refilling bottles is so dangerous how do Calor do it?
Jac Sprat try phoning Go Outdoors.Everywhere seems to be out including Calor online delivery .
Any suggestions?
We’re in NorwichWhere in Norfolk are you?, I have a full 6kg bottle I could lend you.
