CAK Tanks auto defrost element (1 Viewer)
jonandshell
5,476
8,299
Not got one!
Hi all
I was wondering if any skiing Funsters had used one of these successfully to stop an underslung GREY tank freezing.
The website quotes a current draw of 2.5 amps which is fine for us because we are well endowed in the battery department!
The website also quotes that this element will also prevent the freezing of 45 litres of water, in an uninsulated tank, at -25, subject to tank shape.
Well, I intend to insulate our tank and bearing in mind nearly all waste water discharges are warm to start with, do CAK's claims stack up?
If any Funsters have any real time experience of these units in Alpine conditions, I would be grateful for your collective opinions. As mentioned previously, the current draw isn't an issue for us, even off grid.
Thanks in advance!
Jan 8, 2014
1,038
2,519
Emsworth
Bailey 740
Hi I have a burstner travel van and it has a heater element in the waste tank, never used it though, but it must work as the van was partially designed for winter sports.
jonandshell
jonandshell
5,476
8,299
Not got one!
Hee hee!
NEVER believe a dealer or manufacturer's claims about ANYTHING!!!!!:wink:
My judgement says this element should work, but the cold can penetrate in wierd ways once the temperatures plummet.
Having said that, Burstner are quite good vans for those conditions, although I have known a water pump freeze on a double-floored Elegance!:Eeek:
Thanks for the input though.(y)
2,086
9,025
Suffolk Coastal District, UK
Timberland
CAK tank's claim broadly agrees with Tank Blanket .. which draws 5A and protects 121 lt
In the case of TankBlanket, which services a tank up to 121 Litres against a minimum benchmark ambient temperature of -24 degC, and to achieve this using a 12V supply the draw is circa 5A . It is governed by Ohms Law.
The current UK market standard, that is, an in-tank suspended probe has a lower draw, but you have to look at performance. A typical in-tank Frostat probe currently fitted to many Motorhomes uses a 12V supply and only draws circa 2.5A, but it only services a 45 litre tank!
icantremember
8,318
17,527
Near to Watton in Norfolk
Hymer T-SL668
since 2005
Hi all
Thanks in advance!
That appears to assume a full tank ... unless the probe is at the bottom of the tank, where it could get covered with gunge, what would happen to a partly full tank?
Anyway, why would you want to keep a tank of grey waste? Surely better to run directly into a tapered bucket and dispose of as a big lollypop!
jonandshell
jonandshell
5,476
8,299
Not got one!
It all depends where we stop!
We might be neighbours of members of the Motorhome Fun Grey Water Police!
We currently use a bucket, but its easy to overflow it and leave a tomato pasta sauce coloured ice rink!
I plan to fit the element over our slide valve, as low as it will go.
haganap
12,711
25,974
planet earth
Carthago C Tourer
I'm an oldbie MH number 9
Yes i had one on my last van. It helps but even fitted real low won't work for what you want. There is always some amount of water trapped in the pipe outlet which will freeze at harsh vt temps.
The problem is that they do not heat the tank they just stop it from freezing ...There will always be a weak spot in extremes....so do yourself a favour....buy a bigger bucket ;-)
canopus
6,111
10,189
rural Lincolnshire
Carado CV640 Pro
Hi all
Thanks in advance!
If you buy a N+B as you indicated you might do, then you won't need tank heaters.
jonandshell
jonandshell
5,476
8,299
Not got one!
That was the plan, albeit the expensive option!
Theres nothing we like at the moment so I will persevere with our underslung tank until something comes along we like and can do a deal on.
We arent in a hurry! Fools rush in as they say!
jonandshell
jonandshell
5,476
8,299
Not got one!
Dont
Don't have a discharge pipe, just a slide valve straight out the bottom!
You can get 300 or 600 watt 12v elements for about 18 quid. I wonder if I could fit one for emergency defrosting with the engine running?
jonandshell
jonandshell
5,476
8,299
Not got one!
The purpose of the modification wouldnt be so much to store huge quantities of grey water but to give time to make emptying a planned rather than emergency operation!
Allanm
5,431
9,191
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
I fitted them to my Fresh and waste tanks. I also have the tanks insulated, as well as all the pipework including the drain outlets.
Nothings frozen yet in temperatures down to -10.
I'll let you know next year how they perform this winter...
Allan
haganap
12,711
25,974
planet earth
Carthago C Tourer
Yes but there's -10 Alan and skiing in VT....;-) they do work i fitted one in my fresh and never frozen since....seems like a lot of hassle jon get two buckets you lazy git
jonandshell
jonandshell
5,476
8,299
Not got one!
We used a three bucket system last year!
The two thawing in the garage created a cold area which made our batteries inefficient!
I just want to buy a little time between bucket emptying! It would be nice to do it at a leisurely pace, perhaps whilst emptying the cassette! Instead, I'm out there during every shower making sure the bucket doesn't overflow!
Besides, I've committed to the project now! There's a roll of Screwfix foil bubblewrap loft insulation sitting in the garage ready to stick onto the tank! As good as 55mm of polystyrene it says!
We shall see............!
Ivory55
6,017
14,534
North West Norfolk
Since Feb 2012
Spoilt it now, I was thinking that you built a big pile of frozen blocks of ice with the waste from your buckets that did not melt till the spring.
jonandshell
jonandshell
5,476
8,299
Not got one!
At the end of most Aires, there's a pile of bulldozed snow left by the loading shovels they use for snow clearance.
That's where you chuck the great water igloo building blocks!!!
jonandshell
jonandshell
5,476
8,299
Not got one!
Good News!
I am now able to conduct a cold chamber test at a constant -22 courtesy of one of my customers!
Hopefully I should have the element and insulation fitted in a few days. I am then able to place the tank in a coldstore and leave it connected to a battery for a day or so.
I am able to keep the battery at ambient temperature and run a cable into the coldstore. This will mean my battery wont be killed off in the process!
I will post the results good or bad!
jonandshell
jonandshell
5,476
8,299
Not got one!
OK, so the tank has been in the cold store for 9 hours now.
This morning a 0700, I half filled the tank with 50 litres of cold tap water, connected the defrost element to one of my traction batteries and went and did some work!
The ambient temperature is -22, the tank is still liquid and the slide valve is still free to move.
The battery is rather annoyingly still showing 12.8 volts! Which means the insulation must be very efficient because the element has drawn next to no power so far. The element did come on for a short time during the afternoon, during a routine check.
I am back to site at 0900 tomorrow, so I will issue a further update then!
jonandshell
jonandshell
5,476
8,299
Not got one!
Broken Link Removed Chilly, chilly, chilly! -22 degress celcius!
I think this freezer was just large enough for the job!
The defrost element and discharge slide valve.
The element needs sealing again after completion of the test, as indicated by the icicles!
So far, so good!
2,086
9,025
Timberland
Did you measure the temperature of the 'fill' water ?
The test really only starts once the water in the tank reaches the temperature you would expect for tap water in wintertime...probably only 3 or 4 deg c
I just tested my 'cold' tap water at home and it is 19.3 c ..
I think that given enough time the water will eventually freeze.. no matter how much insulation, a 30 watt element won't stop it freezing.. at best it will prolong the liquid state.
I hope I am wrong.. Look forward to the results..
EDIT.. sorry.I was thinking fresh water tank.. . not grey waste. .. doh
jonandshell
jonandshell
5,476
8,299
Not got one!
Hi Jim,
The water going in was approximately 17 degrees.
Of course, waste water discharges from a MH are from the shower, washing up, or washroom sink. All of these discharges are substantially warmer than cold tap water. The only cold water going into a grey tank is from cleaning your teeth!
The cold tap water at 17 degrees presents a 'worst case' in my opinion.
Also, it is never persistently as cold as -22 in the Alps during winter, temperatures are usually close to zero during the day. -22 is extremely low, even for night time.
I am looking forward to the result after 24 hours though. I will check the battery discharge and work out the Ahs consumed.
The intention was never to store water indefinitely but allow at least periods of 24 hrs to ease the workload of continually emptying buckets!
jonandshell
jonandshell
5,476
8,299
Not got one!
Tonight near enough ski will have that loaded on a fresh link or browns fridge motor and it will be half way across the country. By tomorrow morning, ha ha
Ah ha!
I have located the tank close to an unused INLOAD bay! The worst that can happen is it will be buried under several tonnes of peas, chips or Birds Eye ready meals!!!!:laughing:
May 1, 2009
1,005
2,177
SOUTH WOODHAM FERRERS
Ticked the options box for heated tanks when ordering our Autotrail .No idea what we are getting but all other years we have used bucket.We have taken water bottles for a single night aire stay with ski each day and then returned to the lower valley .
jonandshell
jonandshell
5,476
8,299
Not got one!
It is the plumbing that freezes first. On our Chausson, and on many other continental vans, all the water pipes are followed by warm air ducting.
As a consequence, the fresh water system has behaved faultlessly, even when stationary for nearly 2 weeks. If you are able to continually heat your tanks you MIGHT be OK. Other Funsters have managed with underslung tanks when these have been supplemented with well dug-in snow skirts on the van.
What is most vulnerable to cold is any external pipework and any pipework which touches the outside walls or floor of the van.
I think all Brit vans are a challenge in Alpine conditions, those challenges can be overcome, but you need to put the work in!
Look up Haggernap's blog. He has put a lot of time into making his Bessy work in the cold.
Good luck!
jonandshell
jonandshell
5,476
8,299
Not got one!
OK, the test was concluded at 1000 this morning when I removed the tank from the cold store. The tank, along with 50 litres of water had been in -22 for a total of 27 hrs.
My findings are as follows-
The gate valve was a bit sticky, but did open. There was a skin of ice present which needed a finger through it to start draining.
There was a skin of ice over the entire surface of the water in the tank. This extended the full depth of the water in the furthest corner from the defrost element.
This was no surprise given the flat shape of my tank.
Upon draining, I would say 90% of the contents were still liquid.
The battery, a 115 AH Dyno traction monobloc, was down to 10 volts however! The test should have consumed no more than 70 Ah maximum.
Rather embarrassingly for me, the cause of this became obvious when I popped the battery cell caps and found the electrolyte low!!!!! 1.25 litres low to be precise!!
I will write 100 times 'Fast charging consumes water' to punish myself for that little error!!!
Because of the shape of my tank, I realised I would get some ice away from the element. That I can live with.
The persistent temperature of the environment during this test was far lower than experienced in the Alps. The water within the tank was colder than normal waste water discharges are.
In conclusion, I would not trust one of these to keep my fresh tank liquid for very long, if I had an underslung tank. Like Scotjimland pointed out, the element is really only delaying the on onset of frost at these low temperatures.
For my use though, the experiment showed that I will be able to chill out on our ski holiday and empty the tank at my leisure, so long as I do it at least once a day.
I'm happy with the outcome!
jonandshell
jonandshell
5,476
8,299
Not got one!
Well, the tank is back on the van pending electrical installation and my battery is now topped up and on charge.
I think it has forgiven me!!:crying:
