Cable size
That is priceless, probably 16mm cable to a 1,5kw inverter of one battery, and haven’t seen a fuse to the inverter. Thing is that battery can only give 40-50a before the voltage dives and shuts the inverter, before the cable has a chance to warm up.
Problem is that someone could watch the video and mess things up.
You could spend a lifetime correcting the bad information on youtube
but good on you for trying 👍
Difficult to tell but could be 16 or 25mm sq cable. If 25 mmnot too bad, when you consider British manufacturers often use 6mm sq.
