Cable routing on Auto trail
Newent, UK
Etrusco T6900
changing a load of things again
Has any one ever routed a cable from the underside to the control panel above the door. at the back of each cabinet there is a square trunking going the length of the van. but how do i get up the wall?
Thank
Billy
I have done it on the other side and it routes up the rear door pillar, on my Mohawk there is a plastic moulding over the pillar that once removed gives access. Maybe the same for the nearside.
brill is that on the hinge side?
thanks Diablo
No the other side, so on your shoulder, the door Piller should have a plastic moulding held on with a few screws, once removed the cables are ln the pillar which are accessible via some large holes in the steel pillar. I bought a cheep endoscope from fleabay that connects to a mobile so you can see where the wires go.
thanks so much Dane
no no wires going up either side of the door :-( also nothing down behind the fridge. back to the drawing board
When up the van I will take a picture from underneath to show where mine go, yours may be different. Is your PSU in a cupboard near either of the front doors?
yep behind the drivers seat
Most of my cabling goes from the back of the PSU towards the front and down either a plastic moulding or the door pillar can't remember which, I'm up the van tomorrow so will have a butchers. If you take the PSU out (4 screws) you should be able to see where the various looms go for your van as it may be different to my Mohawk. As I mentioned before I got a cheap endoscope camera off cleavage that plugs into my phone, this enables me to like it in holes to see exactly where everything routes.
mine goes it the roof and out the other side above the pass seat then through the cupboards to the back door.
i will take pics this weekend
thanks for your help
Billy
all done
the black sealer just fell out when prodded.
up under the fridge through the to in the corner passed the microwave and over behind the main panel.
small led switch fits nice
then re seal with sicaflx
now have two 6kg bottles for sale one totally new the other 3/4
billy
