Cab & Leisure Batteries Charging (1 Viewer)
Aug 21, 2015
100
55
Southampton
A/T Impala 615
I'm a slightly less experienced newbie and still learning
Moving from caravan so this aspect is new to me.
Have been reading on other posts about keeping both batteries charged, can anyone confirm on Autotrails when connected to the mains both cab and leisure batteries will be kept charged?
With the caravan, only one battery I used to have it on timer for 2 hours a day will this be sufficient to maintain both battery in the MOHO.
Dec 24, 2014
9,877
51,888
Hurstpierpoint. Mid Sussex.
Compass Navigator
Ever since lighting was by Calor gas.
As a definitive answer......when you have EHU connected use a multimeter to ascertain the voltage at the batteries' terminals. Then disconnect the EHU and read the voltages again after say, 20 mins. If the readings are lower than with EHU connected they are being charged. If the reading of a battery is the same as when on EHU then that one isn't being charged.
Apr 6, 2019
4,330
8,550
Eye, Peterborough, UK
RV
FourWinds Windsport 6.8L V10
Only you can tell really. Put a multimeter on a battery when on EHU - if it reads over 13 volts then some charge is going there.
Oct 6, 2021
596
973
PVC
My Auto Trail PVC certainly charges both batteries. I don't need a multimeter to tell me this, the voltage is displayed on the panel above the door. When the mains charger is connected, both batteries show a voltage of about 14.5v showing the charger is supplying both.
Jun 16, 2014
658
2,519
NOTTINGHAM
Autotrail Savannah
Almost a Newbie but not quite now.
On my 2010 Savannah I have to change the selector over to charge whichever battery. This is why I have removed the 2 leisure batteries into the garage to charge infrequently. The vehicle battery remains in situ to enable alarm and tracker to work. This is charged for one hour a day with a cheap Lidl charger, via a smart plug and Alexa. Just checked it and it is showing 13+V. The 2 leisure I check occasionally and they have not been charged for over 2 weeks still showing 12.6v
Lenny HB
55,878
163,042
On the coast in West Sussex
Carthago Compactline
At's normally have a Sargent distribution system most of which are capable of charging the starter battery. But they do it an odd way and it has to be set up on the control panel, they have a smart charge feature that swaps the charging between leisure & starter battery in 4 hour blocks. i don't know much about them but a few people have been caught out with flat starter batteries unaware they need to set the system up to charge the starter battery.
Apr 11, 2015
5,812
60,038
hull
Laika Ecovip 300
Can't help with your van, but today went to storage to check our van, solar and battery master both batteries are above 13, admittedly on the panel but there has never been more than a .1 difference when we use a volt meter
Dec 24, 2014
9,877
51,888
Compass Navigator
Mine's not so clever - just a green LED and a red LED. The red LED lights up when the voltage is below 11.5 which (as far as I'm concerned) is too late.
Jan 28, 2008
10,256
18,643
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
wouldn't it be easier to measure the voltage off hook up then plug in and see it the voltage rises? no need to wait for the float to dissipate
Dec 24, 2014
9,877
51,888
Compass Navigator
(y)
Yes, it probably would.
My post was more a suggestion of a way to tell whether a battery was being charged or not by comparing voltage differentials.
Jun 27, 2021
349
1,144
Lincolnshire, UK
PVC
Seasoned
My PVC has the rather odd Sargent charger which alternates batteries every so often However owing to the constant drain on the starter battery I noticed that the starter battery would occasionally get quite low. Hence I bought an Optimate dual charger, switched off the van built in charger and now use the Optimate to maintain both batteries independently. On hook up at home I just plug the Optimate into a. 240v socket in the van.
I can monitor the charging through the Sargent app.
R
Aug 21, 2015
100
55
Southampton
A/T Impala 615
Thanks for all the responses several ways to tell, from the control panel to using a multimeter, plus checking that the Sargent charger is programmed correctly (all very logical when explained simply) thanks
Mar 14, 2020
774
661
Isle of Man
Autotrail Cheyenne
Since 2015, still learning
What age is your autotrail? Some era vans need the control panel to be used to select which battery receives or gives the voltage.
Cush
