In the bad old days when we had a caravan, we used butane in the summer and propane in the cooler months without any problems. Just swapped the regulator and all our appliances worked perfectly.
Now in this new improved world, we don't need to swap regulators, one bulkhead one is supposedly suitable for both (unless I've misunderstood how it's all supposed to work).
Anyhow, fast forward to our current holiday in France, when, because of its duration I thought it would be wise to switch to butane for its better gas economy and duration. Bought a new HP pigtail, swapped the cylinders, tested it all and everything seemed fine. "Fine" that is, until firstly our Dometic oven tried to kill us with carbon monoxide and secondly our fridge died due to a chimney full of soot after a week of operation, mostly on gas (but by no means totally).
Now I'm annoyed at myself for not spotting that Hobby do say in the vehicle handbook that it's set up for propane but also annoyed that they have put explicit warnings about NOT using butane.
Also annoyed with Dometic for making appliances that don't seem to be "dual fuel" (unless it's all down to the wrong regulator) and annoyed that motor homes have "advanced" so much that you just can't swap gas supplies the way you used to be able to.
Fortunately we have a CO alarm and a full tank of propane so we're back to "normal".
Tempted to rip out the bulkhead regulator and go back to "proper" separate propane/butane regulators. I'm sure the supply pressure is just too high for butane to burn cleanly.
Have I been an idiot or are other folk under the misapprehension that the bulkhead regulator was suitable for both fuels?
