movan
That was going to be my suggestion, bike loop switch, if you have the growler alarm it should have a socket under the back, it a trailer type socket.
Socket might be missing..
Just so you know you can’t see the socket unless you look right under the rear bumper.
Yes . I didnt know what it was as it was loose on bed. I thought I put it in my garage at home but it not there so I wonder if it been thrown away with old stuff.ours clips into the back of the wardrobe have you checked its not there
315 long 60mm diameter one end is flat and the other has a 30 mm diameter hole in it its actually a piece of 60mm ally tube with plastic stoppers in the ends if you want a picture/s send me an email
@movan
you want a wood turner really, mind you i could be square it doesnt matter it only holds the table up if you look at the tall leg you have the top will be the same
