Boxer oil. (1 Viewer)
Oct 19, 2017
257
183
Cornwall
Class C?
Returning to a motorhome.
I have a boxer based Autocruise Vista with the 1.9 td engine. It was serviced before I bought it, but I don't know what oil was used. Would it be more likely to be synthetic or mineral? Not knowing, is it safe to mix if I get it wrong. Is it best to drain it and start again?
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
DuxDeluxe
14,658
72,693
Planet Zog
A woosh bang van
since 2008
A slightly more helpful answer than the above irrelevant comment is that it is probably 5 or 10w -40 semi synthetic
A bit of discussion on the fiat forum here.... https://www.fiatforum.com/ducato/428163-engine-oil-1997-ducato.html although it is a fiat forum the engine is the same. I checked on the Peugeot 1.9td with the same answer
Hope that is of help - it seems that mixing may not be an issue with that type of engine
Edit. Just found this on BP Castrol site which might help as well though that is a fully synthetic oil - just enter reg number https://applications.castrol.com/oi...1994-2006)&modelType=boxer-1-9-td-(1994-2002)
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
J
Oct 19, 2017
257
183
Cornwall
Class C?
Thanks DuxDeluxe, most useful. And EX51SSS it did make me laugh!
The Nomad
1,052
1,064
Wandering in Europe
Overcab
Many years
Do not put a 5 weight oil in an older engine. The crankshaft seals were never designed to cope with such thin oils; it will weep past them into the clutch bellhousing and potentially contaminate the clutch.
A 10 or even 15 grade mineral or semi synthetic is viscous enough for the oil seals to cope with.
Any decent brand of 10 w40 or 15w40 semi synthetic.
Aug 6, 2013
11,953
16,567
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
I'm trying to understand how viscosity has any bearing on oil seals? Once we moved on from wetted felt it ceased to be a concern.
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
If it’s any help, I use Total 10w40 semi synthetic in my 1997 2.5 tdi, I used the same grade mineral oil last oil change, ( it was all I could get in France at the time) and the semi synthetic certainly quietened the engine a bit. Mrs A commented that it sounded quieter and felt smoother.
I would recommend 10w40 semi synthetic.
The Nomad
1,052
1,064
Wandering in Europe
Overcab
Many years
Google it or search the Fiat owners forum or check with other experienced mechanics who've worked on these old engines for several decades now.
Or just don't believe me and put a 3 or 5 weight oil in just to see how long it takes to start weeping past your crankshaft seal.
Aug 6, 2013
11,953
16,567
Kendal, Cumbria
since 1999
I don't disbelieve you and I've heard it before. I just don't understand it. Scroll 'seals' and felt or rope needed heavier oil but lip seals contact the shaft. Once that happens they seal as long as there's oil to lubricate the lip. The other issue is that a non-synthetic at 10 can be no better than synthetic at 5 once the engine is hot. So, as l said, l don't really understand.
J
Oct 19, 2017
257
183
Cornwall
Class C?
It's the same with my Moto Guzzis. Synthetics will leak past the seals.
Bailey58
8,801
29,458
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
Well it made me laugh too and I've yet to see a thread asking for info that doesn't produce a witty comment or a pic of someone munching popcorn. :)
