Does anybody know what the cover is on the bodywork underneath the fridge vent, is it original or a panel to cover damage. And why only 1 fridge vent when its a separate freezer one?
I think you will find the upper vent exits through the roof.
I don't know but wonder if it could be service access panel to get to the burner.
Is it not possible to unscrew it to have a look?
Don't see why it matters , if it's to cover damage it's a very thorough way to do it.
It could be to cover a space left from something that had been fitted and now removed or it could just be an additional vent or something previous owner has fitted
You know how folk like to add things
Maybe a fridge fan or something
Either way it looks tidy enough I wouldn't let it effect my purchase
I like that opening window idea on the door
But I'd break that it's guaranteed
I thought you'd ordered a panel van?
Is it possible that the dealer may have mis-understood your question? I think the toilet will be further to the rear and beyond a shower cubicle. The toilet vent could be through the cassette access door but I'd expect it to be through the roof.Dealer emailed just now, its the toilet venting, very strange, why there. It was the only thing I could think of though.
I'd be more concerned about water getting in than a thief.So could a thief, force the window open and hand in door open, easy...
It's a good place to fit a BBQ outlet if only because of easy access to the fridge gas supply.
Smartar*seYes but the barbecue outlet is clearly seen below the cover I am referring to.
As the cover appears to be screwed in it is not intended for regular use. My guess would be:
1. It covers a hole previously used for an appliance adaptor box. e.g. BBQ point, external power point etc.
2. Looking at the location of it and the layout of the van it appears to be on the join between the fridge and the shower. Could be the shower tap needed to be changed and rather than dismantle the whole shower room an access hole was cut to get to the tap and connections.
On a general note the fridge is very high up with a cooker under it, will the heat from the cooker affect the fridge and more importantly with the freezer so high you (or SWMBO) is going to have to stretch for the ice for the G&T
