I have votronics mppt and b2b controllers, currently use an issolator on battery negative for winterization.
Now the bmv712 has a relay that can be controlled by SOC level. Heres an experiment, Pick a level to switch on external relay. I start at 59% (solar on relay closed) set come on at 61 off at 62% . Once solar takes level to 63% (relay open) switch off solar put on lights. The drain takes soc down slowly, then it hits 61%. Im expecting the relay to go open to close nope some time later ( at least 8 mims) it does goto close. no relay delay setup, relay mode is set to default. I cant see anything relevant in the manual.
From photos bellow note time remaining and relay state. ( what is namm?)
Anyone know or done simular?
Im assuming the simplest method to go from summer to winter to max use is to change the % settings.
Still waiting delivery of a relay to try in practice.
