Being a bit Mutt and Jeff and aware that I have the tv volume up most of the time I thought I had come up with a solution. I bought two pairs of Bluetooth headphones and a little Bluetooth transmitter to plug into the headphone socket of the tv for us both to use. I assumed that the signal from the transmitter would be picked up by both identical headsets but that isn't the case. I can run either of the headsets but not both at the same time so assume that they both operate on different frequencies? If this is the case is there any way I can buy a "double" frequency transmitter so each headset could be paired separately, or if I split the signal from the tv headphone socket into two Bluetooth transmitters could I pair each one with a headset, or are there any other problems I haven't thought of that would prevent this from working? Can you buy transmitter and two headset kits ready made? As you can see I don't know much about Bluetooth!
