Blaupunkt sat nav - how to turn radio off? (1 Viewer)
Southdowners
3,358
25,320
West Sussex
Concorde Charisma
Since May 2015
We want the audio on for the sat nav but can't seem to be able to do so without the radio coming on on too.
We've checked the instruction manual and it says you can select the audio for each system individually and have muted the radio. The trouble is that every time there's a sat nav instruction, the radio comes on again.
Can anyone help please?
Lenny HB
53,301
149,461
On the coast in West Sussex
Hymer B678 DL
It's the same with all the combined units, you can turn off the sound but you loose the satnav sound as well.
What you need to do is select an input you are not using such as Aux1 or Aux 2. My TV is connected to Aux 2 in my unit so I select that as there is no input with the TV turned off.
Southdowners
Southdowners
3,358
25,320
West Sussex
Concorde Charisma
Since May 2015
Thanks Lenny - will try that.
It's strange that you can't just select the volume independently isn't it?
Jul 4, 2012
105
207
somerset
Concorde 791RL
15 years
Same here, have to put it to aux1.
D
deleted-member02
I just turn the volume down on the radio, while the sat nav voice remains at a constant level.
There’s a sub menu to adjust volume controls, to achieve the correct ‘balance’ of sounds.
It took me a while to discover and master this function.
I have no idea if Blaupunkt units have this functionality!
Southdowners
Southdowners
3,358
25,320
West Sussex
Concorde Charisma
Since May 2015
Yes, there's a sub-menu and I turned off the radio volume and raised the nav volume. I thought that would sort it, but no. The problem was that as soon as the nav audio came on the radio did too.
D
deleted-member02
So if you turn the radio down it’ll be quiet until a navigation instruction resets the volume. I can see how annoying that would be. Aux input it is then...
Perhaps YouTube has some answers, there must be plenty of Blaupunkt owners out there!
