- Jul 5, 2013
- 11,726
- 13,704
- A class
- Since 2013
Thanks. I thought so to.That is just so comforting to him.
The white thingy with the O rings looks like an air admittance valve. If it is then it is there to let air into the sealed system to prevent a vacuum forming, but not let air (and therefore bad smells) out. If you are feeling lucky you could always try blowing and then sucking. You should be able to blow air in, but not suck any air out. But if I am wrong you could end up with a mouthful of s**t. Well at least its your own.
I don't know, it may be allowing air into some other part of the system?not really sure what function it will serve now I have found the wider bore vent pipe to the roof, wont that do the same ?
What is the small pipe in the photo next to the black drain. Get an £8 quid USB camera with a few meters of lead and feed that it into the vent to see where it goes and what condition its in.
