Black Marking on Garage Door Lock
Dec 2, 2010
928
1,771
Hollywood, Birmingham.
A Class Laika
Since 2011
The gasket around the door lock is leaching colour, is there a way of preventing this? I am not sure if replacing the gasket would be a solution in that a new one would also leach colour.
I would be grateful for any advice.
Mike
Feb 8, 2014
1,555
2,439
Sheffield
Eldis Majestic 115
Vans and tugs since mid 70's
Looks like similar lighter marking above the lock? new seal should sort.
quickweh
Dec 2, 2010
928
1,771
A Class Laika
Since 2011
Thanks, checked with Southdowns and they only supply the lock complete with gasket. May try spraying the gasket with lacquer or replace with a large 'O' ring.
Glandwr
Banned
Jul 10, 2014
1,057
3,301
the Berwyn Mountains
Hymer S740
since 2009
You could cut one out of an old bike inner tube. Very handy things, everyone should have one in their garage :D. Should be able to get one free from your local friendly bike repair shop.
ymfb
799
6,365
Salisbury
AS Kingham
Since 2009
Use a different material for the gasket as the present one is breaking down and will leak sooner or later.
You need to determine the thickness, before you buy then get something that is suitable for outside use.
If you can find a gasket maker, they will I’m sure sell you a square metre. At work we use Camthorne at Stoke on Trent
Oct 9, 2017
337
716
Wisbech
2007 Hymer B654
There is some staining above the lock also, so nothing to do with the gasket. The shape of the lock looks to be concentrating the flow from above to the outer bottom corners. Some leaching may be coming out of the rubber gasket, or could be coming off the lock itself. I would give it all a good clean up and then put a few layers of good wax polish above and below the lock so that any run-off would be less prone to leaving a black stain. There may be a product on the market that could be brushed onto the rubber to seal it. I would, certainly at this stage, leave the gasket alone.
Jul 5, 2013
9,925
10,471
Tunbridge Wells
Since 2013
Not sure that the gasket is doing the leaching, unless water can travel uphill by itself. Looks more like the usual grey streaks coming of the roof and accumulating where the flow of water down the wall when it rains slows down, i.e. above and below an obstruction
Lenny HB
32,469
61,808
On the coast in West Sussex
Hymer B678 Dynamic Line
I'm not sure if its the gasket also. If you want to replace it, remove the gasket put a 1-2mm bed of Silicon RTV (room temperature vulcanising) compound on the surface after refixing excess can be wiped off with white spirit. RTV Silicon is used instead of gaskets when rebuilding engines, Pacer Pro Seal is one of the best brands, avalible at most auto factors and accessory shops or on eBay.
Ambilkate
8,391
14,461
Shropshire
HYMER 654
since 2006
Bill thinks it could be that gasket breaking down, Bills just cleaned all our black streaks with the elbow grease solution £1 from pound land.
Kate
