Emmit
Got one of those for the Dog, just asked her and she really rates it!
No. What she said was that showering that way was "Woof"
.................I'll get me coat.
Don't think 5L would be enough for a 'human' especially if washing hair and the flow looks very low ... however the feel of the brush might be rather nice!Bit off piste I know, but I've just bought a MudDaddy to wash off the dogs. I do have a shower hose from back of van but only cold water. This way I can heat water and use after beach trips etc. States water stays hot for couple of hours. Holds 5 litres but works under vacuum pressure. I haven't tried it yet but I'll probably try it for me too at some point. (Disinfecting between washes ).
We used exactly the same as @Popeye only home made out of a submersible I had in stock.Besides the shower inside the van I also use a solar shower which I used on the yacht on hot days and a 12 volt one for washing down our bikes or shoes or wet suits / sandy feet.
Mine is like THIS ONE but with a straight forward cigar lighter connection which I plug in almost anywhere on the van, Garage or through a window.
This one is almost even better as it has a rechargable battery so you could use it away from the van even down on the beach.
Rechargable Shower dip it in the solar shower bag first thing in the morning heated elsewhere/cooker etc
....and an old inner tube with a few holes in it I suppose, my god Paul you're such a cheapskate........We used exactly the same as @Popeye only home made out of a submersible I had in stock.
The problem with pump-up systems is that you're not going to get the pressure you want along with the length of time you need for showering, even with the quick shower method, so you'll either end up with a very low pressure shower that might last long enough, or you'll end up with a good water rate but it'll stop whilst you're still soapy! Having used manual pump system sprayers etc I certainly wouldn't want to rely on one for a shower, for washing hair or something like that they'd be fine but then you can use a washing-up bowl and beaker!I've been looking at a pump up system, my friend said the advantage of that system is your not relying on electricity in any way Ive been looking at the Hozelock system . I wondered if any of you have tried it or something similar ?
as above, i have exactly that fitted with a trigger release shower head. works great but limited to 7ltrsI've been looking at a pump up system, my friend said the advantage of that system is your not relying on electricity in any way Ive been looking at the Hozelock system . I wondered if any of you have tried it or something similar ?
