Beep beep beep
North Yorkshire
since 2000
Happy Christmas everyone, we have blue sky and frost.
We have just been for a run in the Motorhome. Carthago Chic E Line Before putting it in the barn. Each time we went round a roundabout something beeped in the rear. It was 3 beeps/3 beeps until we straightened up again. We stopped and checked that the drawers were locked. It sounds like the noise the fridge makes if we leave the door open. The control panel is turned off. We have air suspension but there were no warning lights, the handbrake is in its correct position, I can’t think of whatever else beeps, I obviously missing something, help please.
If you have a tow bar, could it be the electrics interface for the trailer lights ? Most beep when the indicators are put on
Road runner trapped in the garage? :xwink:
Yes happened to us a few weeks ago , although ours is a panel van and it turn out to be the door open light. The moment of a fraction of an inch was enough to move the sensor
Seat not fully down, happened to me , poorly adjusted proximity switches.
Thanks all, please keep trying.
Casper would have noticed road runner. We will check brake fluid, but the noise is inside towards the rear. No tow bar and everything drained down. Microwave lives in the garage and it makes a different noise. Nothing to do with indicators. Ctc I'm not sure which seat you mean.
If we don't find it I'll have to let him drive and I'll have a listen in the back. Hopefully it's something daft.
Not too close to something perhaps? My car used to beep if someone got too close to the reversing sensors in slow moving traffic.
No traffic, everyone still in bed when we went out. No beeping sensors either, we have a birds eye view system.
On my Laika, (CBE electrics), I get an irregular beeping noise when the freshwater tank is almost empty.
It doesn't have a nearside blind spot alarm does it? The bl**dy thing was forever going off in the truck i used to drive, whether there was a cyclist up the inside of me or not.
We can put water in it and try, thanks.
No alarms, I have a blind spot camera.
Was you in reverse gear? Mine beeps to warn people 😂
We get that on the Laika when water tank is empty, in fact we have had that on all vans when they were empty. Very annoying. we let the water get really low as draining down in the morning and then slept in it afterwards, the bleeping woke me up several times.
We had the same issue, someone on the forum (sorry can't remember who it was) suggested it was the low level sensor on the fresh water tank, sure enough, adding a few extra ltrs of fresh water cured the problem.
My cab seats go up and rotate, when in the driving position contact must be made with the switches. Also it only has one buzzer for the cab step, the seats and the habitation door step.
