Kitch
Off to France soon, first time, I have had a good look but cant find an definite answer and the dealer we bought from cant give an answer either, do I need deflectors on this type of headlight.
thanks
Two minute job on mine.Lenny is right.
What he doesn’t mention is just how big a bitch of a job it is to get at the back of the unit on most A class vans
I’ve never bothered adjusting mine.
When have you ever seen a foreign vehicle in the UK using beam deflectors and I've looked ?
Are you going to be driving at night while abroad ?
If it has a leveaver you have to take the rubber cover of the back of the lamp and it's around the back of the reflector.
Most people set them for flat dipping and leave them permanently like it.
If your van is a UK supplied LHD it will be set for flat dipping.
Don't think the E5 is anything to do with it.There isn't a rubber cover, it seems to be a sealed unit, do you think the E5 hex would have something to do with it? with the 2 long bolts at the top.
Come to think of it, I haven't seen a foreign anything with beam deflectors onHas anybody seen a foreign MoHo with beam deflectors fitted
Really interesting and useful thread
I've just had a look at ours (they are not the round Hella lights).
There is a round rubber cover at the back of the light (really difficult to access of course) but under the cover I can't easily find a lever and I don't want to poke around too much. Looking at the lights I think they may have a "flat beam" but we will have a proper look once we are on our way, just to check if there is a bias for dipped main beam.
We do have the stick on deflector things if necessary (not put them on so far).
It might not be a lever. I seem to remember reading that it’s grub screws on mine but I’ve never bothered looking so I don’t know for sure.
is the EU law still in place that all vehicles should have dipped headlights in the day, not seen any change myself but might have missed it.
If it is grub screws there isn't space to get to them!!!
I don't see the relevantance of that just because someone else breaks the law it does not give you the right too.When have you ever seen a foreign vehicle in the UK using beam deflectors and I've looked ?
If you have plastic headlamps could work out very expensive. They are designed only to be left on for a few weeks. Leave them on too long and the adhesive migrates into the plastic and wrecks the lens.On our van which was a Fiat base I just bought some stick on things and slapped them on. I didn't do it as per the instructions. They stayed on for 5 years and no problem with MOT.
You don't go very far on your holidays then.Do you really want to go to through the hassle for a less than 2 mile journey to Cite de Europe when the roads are going to be empty
Yes Ever since the genderms had a purge around Calais about 10 years ago.So are you really whiter than white then ???
