Anybody know where the drain tap is for the fresh water tank on the above ( not the frost dump valve ) i prefer to leave empty but cant find it and not in manual .
Pop into the right hand side rear garage then look right and you can remove a panel which gives you access to the top of the water tank.
Unscrew the big black screw cap and then reach in (directly beneath the screw cap) and you'll find a very small grey rubber bung. Pull that.
It sometimes comes with a small chain connected.
If your tank has water in it then expect a wet arm.
All the best,
Andrew
