- Jan 21, 2020
- 257
- 163
- Burstner
- Newbie
I have very recently purchased a motorhome and p/e my caravan.
In the caravan I had a Car Current Tester, permanently attached to my leisure battery, so I could monitor the amp draw or or top up coming from my solar panel.
At least I am reasonably sure that is what I had, a - number was always higher the more devices I turned on and a + number when very little draw and a nice summers day, going into a partially depleted battery.
I wanted to do the same on my Burstner but I am not getting the readings I would expect, they are always - numbers, I can certainly increase the Amps being drawn by turning on all the lights and the playing a dvd i the tv, but with everything largely switched off I still get a -0.3A regardless of how sunny the days is.
However, the battery IS being recharged, because having run it down yesterday to around 12.5V, it was again showing 13.8V when I checked it midmorning today.
I am hoping someone on here could point out the stupid thing I have done or not understood!
I am attaching a couple of photo's of the device and my battery compartment, which shows where the device connects to, basically replacing the fuse from the solar charger .
Hope someone can spot my dumb mistake. :-(
