Battery replacement (1 Viewer)
david101
My question is I wish to switch over from my existing lead acid batteries to lithium
In my motorhome Chausson flash.
I have already purchased votronic VBCS 45/30/350 Triple Converter
I intend to buy 12V, 2.4kWh LiFePO4 set with 200Ah cells , BMS mobile monitoring
( would love to have 400 amps but just a little big)
Is it Difficult to bypass the existing charger distribution system habitation side ?
I have spent quite a few hours around the internet looking for similar fruitlessly
Thanks david
19,346
30,232
I would think so, but what system is in the Chausson now?
May 7, 2016
7,256
11,741
West Sussex
Since 2003
I fitted a LiFePO4 to my Hymer. Initially I planned to disconnect the mains from the Schaudt EBL to stop it charging. I was told by Schaudt that all I needed to do was pull the 12v charging fuse and connect the new charger directly to the battery (fused).
D
david101
Hi Martin
CB516 switch mode battery charger
Believe it or not just with pausim's reply, has simplified the process in my head , but all comments,
advice suggestions really welcome
david
May 7, 2016
7,256
11,741
West Sussex
Since 2003
With the CB516 charger being separate from the distribution box it might just be a matter of unplugging it. The Schaudt EBL is a bit more complex because it combines charger and distribution.
D
david101
hope so thanks so much will investigate
david
