ojbristow
- Nov 26, 2022
- 2
- 0
- Transit14 Self Bulid
Hey all!
Currently converting a van and on the electric side of things now, all hooked up and working. Have a pair of new 95ah batteries (AGM) linked together and hooked up to solar panels, split charge relay, inverter and other minor elctrical devices.
The panels that have volt readings built in (Solar controller, invertor and diesel heater) show the batteries seem to drain very quickly from 12.9 to 12.4v. This is when using x6 led lights or just the diesel heater, super low loads which shouldn't even make a dent in the charge.
I have now unplugged everything fully charged with mains charger both batteries individually and verified they are now fully charged. Hooked electrics back up. Ran minor applicances for literally about 15 minutes. Now the volt meter readings on the invertor and solar controller are reading low voltage again at around 12.5v. Unplugged everthing and checked the batteries are actually running at 13.0v and 12.9v so I don't think the batteries are at fault.
Is there anything that could be causing the false readings on the devices when they are linked together? Hopefully it's just me being daft and missed something silly but I'm puzzled and figured to put the question out there.
Hope this makes sense, thanks!
Owen
Owen
